 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,816 Points: 17,600 Location: ipswich
STAGE 57A:
Radiator, firewall and connections.
NOTE: Many of the steps here are quite fiddly and some are difficult to follow in the printed instructions. If you are unsure about any of the tubes/wires/pipes, look at the build stage for that part to see where it is located. For example, for hose 46N, look at the steps in stage 46.
Pic 1: To begin, you might be advised to tape the electrical wires together with low tack masking tape to keep them out of the way.
Pic 2: Locate the firewall assembly and place it just behind the engine.
Pic 3: Fit the thin blue hose 52H from under the reservoir to the pin indicated on the connector. Hose highlighted in yellow.
Pic 4: Fit the thicker blue hose from under the reservoir to the pin facing up on the end of the connector. Hose highlighted in yellow.
Pic 5: Fit the thick black heater hose 56Q to the thick pin on the firewall as shown. Hose highlighted in yellow.
Pic 6: Fit the free ends of the two orange tubes to the pins on the firewall as shown.
STAGE 57B:
Pic 7: Fit the end of the brake servo hose 52L to the lower pin on the ABS module.
Pic 8: Connect the thick orange hose from the reservoir to the black pin on the top of the cam cover as shown.
Pic 9: Connect the thin orange hose 52J to the end pin on the connector as shown. Connect the other blue hose 52H to the lower pin on the end of the connector.
Pic 10: Feed the blue hoses 46N and 46P through the holes in the rear firewall.
Pic 11: Fit the two brake ducts 52P to the two pins on the lower side under the reservoir. Hoses highlighted in yellow.
Pic 12: Fit the firewall in place and secure down the inside right corner with 1 x BM screw.
Pic 13: Fix the top outer corner with 1 x BM screw.
STAGE 57C:
Pic 14: Fix the opposite corner with 1 x BM screw.
Pic 15: Undo the CP screw holding the reservoir 49B in place and remove both reservoirs. Do not lose the screw.
Pic 16: Feed the long flexy-hose 53J along the side of the battery as shown.
Pic 17: Connect the shorter hose 53K to the pin on the reservoir.
Pic 18: Re-fit both reservoirs and fit the removed CP screw.
Pic 19: Turn the car over and fit the radiator brace 57C and fix with 2 x IM screws.
Pic 20: Retrieve the LED wire 42C and fit it to the inside of the radiator part 57B and tape it in place with pieces of tape 22D. Leave approx. 1.85 in of LED exposed at the top.roymattblack attached the following image(s):
STAGE 57D:
Pic 21: Press-fit part 57H in place as shown.
Pic 22: From the other side, fit part 57I.
Pic 23: Fit the radiator base 57F as shown and fix with 2 x AP screws.
Pic 24: Press-fit the radiator top 57D and the cap 57E in place. The parts will only fit one way.
Pic 25: Fit the relay 57J. The part will only fit one way.
Pic 26: Fit the connector 57G as shown. The part will only fit one way.
Pic 27: Store everything safely for now.roymattblack attached the following image(s):
STAGE 58A:
Radiator 2.
Pic 1: Retrieve the radiator from the previous stage and locate the shroud 58A.
Pic 2: Fit the shroud as shown and fix with 4 x CP screws.
Pic 3: Fit the LED strip 42C over the shroud as shown and fix with the press-fit clips 58B and 58C.
Pic 4: Fit the brackets 58F and 58G as shown.
Pic 5: Temporarily remove the horn 20D from the chassis frame.
STAGE 58B:
Pic 6: Fit the radiator assembly in place, starting with the relay as indicated.
Pic 7: Fix from underneath with 3 x CP screws.
Pic 8: Attach the blue and orange hoses as shown.
Pic 9: Fit the air conditioning radiator 57A in place and fix with 2 x KP screws.
Pic 10: Re-fit the horn 20D.
Pic 11: From underneath, fit the hose 58D locating the blue end on the radiator and the other end on the black fitting just behind the alternator.
Pic 12: Fit the top hose 58E in place as shown. The angled engine end should be fitted to the thermostat housing after fitting the blue radiator end.
Store the model safely.
STAGE 59:
Intercooler 1.
Pic 1: Locate the intercooler parts 59A and 59B. 59B will fit on top of 59A.
Pic 2: Parts assembled.
Pic 3: Fix from the other side with 4 x TP screws.
Pic 4: Press-fit the two edge panels 59D and 59E.
Pic 5: Press-fit the rear panel 59C as shown.
Pic 6: Fix the two brackets 59F to the bottom of the assembly as show. Do not tighten the screws.
Pic 7: With the main assembly upside down fit the intercooler in place as shown.
Pic 8: Swing the two brackets toward the rear and fix them to the frame with 2 x CP screws. (Brackets highlighted in grey) Tighten the other two screws.
Store the model safely.roymattblack attached the following image(s):
STAGE 60A:
Intercooler 2.
Pic 1: Press-fit the turbo sensor 60H to the intercooler pipe 60G.
Pic 2: Press-fit the assembly to the pin on the lower side of the turbo as shown.
Pic 3: Fit the next hose 60F through the hole in the sidewall and onto the end of hose 60G.
Pic 4: Connect hose 60G to the end of the hose previously fitted and to the connector on the intercooler.
Pic 5: Wiggle the hose 60I behind the radiator and connect it to the pin on the end of the throttle housing.
Pic 6: Turn the model upside down and fit the hose 60J as shown.
STAGE 60B:
Pic 7: With the model the right way up, remove the NOS tank assembly.
Pic 8: Connect the 2 x hoses 60L to the pins under the tanks.
Pic 9: Connect the fitting 60K to the ends of the hoses.
Pic 10: Refit the NOS tank assembly and connect the ‘Y’ fitting to the hole in the side of the large blue hose previously fitted.
Pic 11: Fit the clear hose to the end of the intake sensor, and the outer pin on the intake pipe as shown.
Pic 12: Fit the stabilizer bracket 69C to the top of the suspension turret as shown. Fix with 3 x IM screws. NOTE: 60C can be identified by the larger hole in the upward flanges which must face the front of the car.
Pic 13: Fit the stabilizer bracket 60B to the top of the suspension turret as shown. Fix with 3 x IM screws. NOTE: 60B can be identified by the larger hole in the upward flanges which must face the front of the car.
Pic 14: Fit the stabilizer bar 60A as shown and fix through the front holes in the brackets using 1 x FP screw on each end.
Store the model safely for now.roymattblack attached the following image(s):
STAGE 61:
Interior floor.
Pic 1: Locate the floor 61A and carpet piece 61B. It will fit as indicated.
Pic 2: Carefully peel the backing from the carpet piece and starting at the rear and tight against the transmission tunnel, stick the carpet in place pressing it into the shape of the floor.
Pic 3: Repeat with carpet piece 61C on the other side.
Pic 4: Fit the tunnel side piece of carpet 61D in the same way, keeping it tight against the floor.
Pic 5: Repeat with carpet piece 61E.
Pic 6: Store the assembly safely for now.
STAGE 62A:
Pedals.
Pic 1: Retrieve the floor from the previous stage and locate the carpet piece 62H. It will fit where indicated.
Pic 2: Peel the backing from the carpet and line up the upper edge with the groove detail on the sill. Stick the carpet along the top edge and then down toward the floor.
Pic 3: Repeat with the carpet piece 62I. (Incorrectly labelled 61I in the printed instructions)
Pic 4: Press-fit the footrest 62E in place where shown.
Pic 5: Locate the pedal parts 62A, 62B, 62C and 62D. Note 62B and 62D are shaped differently and should be fitted in these positions.
Pic 6: Pedals assembled.
STAGE 62B:
Pic 7: Fix the assembly to the floor where shown using 1 x AP screw.
Pic 8: Fit the front left panel 62F as shown.
Pic 9: Fix from underneath with 2 x CP screws.
Pic 10: Fit the front right panel 62G as shown.
Pic 11: Fix from underneath with 2 x CP screws.
Pic 12: Store the assembly safely for now.
