 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,856 Points: 17,720 Location: ipswich
STAGE 57:
Rear right suspension 4.
Pic 1: Retrieve the assembly from the previous stage and locate the arm 57A. It will fit in the backplate 55A where indicated.
Pic 2: Fit the parts together as shown and fix with 1 x S screw.
Pic 3: Fit the deflector 57B to the backplate, fitting the pins on the deflector into the holes on the backplate. Fix with 1 x R screw from the other side.
Store the assembly safely.
STAGE 58:
Rear right suspension 5.
Pic 1: Retrieve the assembly from the previous stage and locate the outer cover 58A. The pins on the upper edge will locate in the holes on 55A where indicated.
Pic 2: Press-fit the part into place.
Pic 3: Store the assembly and unused part safely.
STAGE 59:
Rear right suspension 6.
Pic 1: Locate the disc 59A and fit the hooked end of the outer strip 59C into the slot on the edge of the disc.
Pic 2: Wrap the strip around the disc and fold in the other end into the disc.
Pic 3: Locate the other disc part 59B. It will press-fit onto the disc assembly.
Pic 4: Parts assembled.
Pic 5: Retrieve the assembly from the previous stage and fit the disc in place as shown.
Pic 6: Press-fit the hub 58B in place.
STAGE 60:
Rear right suspension 7.
Pic 1: Retrieve the assembly from the previous stage and locate the caliper 60A.
Pic 2: Press-fit the caliper in place as shown.
Pic 3: Store the assembly and unused part safely for now.
STAGE 61:
Rear right suspension 8.
Pic 1: Retrieve the assembly from the previous stage and locate the disc part 61B.
Pic 2: Peel the backing paper from the back of 61B and stick the disc to the surface of the brake disc as shown.
Pic 3: Store everything safely for now.roymattblack attached the following image(s):
STAGE 62:
Tyre rack.
Pic 1: Fit the wheel carriers 2 x 62C to the ends of the tyre rack 62A as shown and fix with 1 x KK screw in each. The printed instructions have labelled the screws āEā.
Pic 2: Fit the wheels 2 x 62D in place as shown and press an axle 62E through the carriers.
Pic 3: Assemble the other side of the tyre rack in the same way.
Store safely for now.
