1989 Batmobile Official build STAGES 27 - 32 Options
#1 Posted : 26 April 2026 13:59:25
STAGE 27:
Right machine gun.
Pic 1: Fit the piston 27-7 into the sleeve 27-8 and then attach the parts to the support bracket 27-6 using 1 x ‘L’ screw.
Pic 2: Fit the cover 27-9 in place.
Pic 3: Fit the top cover 27-5 into the edge of the gun housing 27-2 as shown.
Pic 4: Fit the spring 27-4 onto the firing pin 27-3.
Pic 5: Fit the assembly inside the gun body 27-2 as shown.
Pic 6: Fit the assembly from step 1 into the gun as shown.
Pic 7: Fit the other half of the gun 27-1 in place and fix with 1 x ‘H’ screw.
Pic 8: Store safely for now.
#2 Posted : 27 April 2026 11:52:11
STAGE 28:
Right machine gun 2.
Pic 1: Press-fit the muzzle 28-3 onto the end of the barrel housing 28-4 as shown.
Optional detail:
You can carefully fill in the recesses on the housing with a fine black Sharpie to enhance the look.
Pic 2: Retrieve the gun assembly from the previous stage and fit the barrel 28-2.
Pic 3: Fit the housing over the barrel as shown.
Pic 4: Press-fit the magazine 28-6 into the side of the gun body noting which way up it goes.
Pic 5: Lift the top cover.
Pic 6: Press-fit the bullet strip 28-5 in place as shown and then close the cover.
Pic 7: Store the assembly and unused part safely.
#3 Posted : 28 April 2026 12:29:27
STAGE 29:
Right disc launcher.
Pic 1: Fit the bracket 29-2 and cover 29-1 together as shown and fix with 1 x ‘G’ screw.
Pic 2: Push-fit the disc holder 29-3 into place as shown.
Pic 3: Locate the disc parts 29-4 and 29-5.
They will press-fit together.
Pic 4: Disc assembled.
Pic 5: Store the parts safely for now.
#4 Posted : 29 April 2026 10:10:08
STAGE 30:
Disc and gun compartment.
Pic 1: Locate the disc parts 30-2 and 30-3.
Pic 2: Parts assembled.
Pic 3: Store everything safely for now.
#5 Posted : 30 April 2026 10:05:42
STAGE 31:
Right front wing.
Pic 1: Position the wing 31-1 upside down and fit the gun compartment 30-1 in place as shown.
Fix with 2 x A screws.
Pic 2: With the wing on its side as shown, fit the gun cover 31-2 in place and fix with 2 x A screws.
Pic 3: You can fit the machine gun here.
It is attached with magnets.
This is an optional fitting.
Pic 4: Alternatively you can fit the top cover 28-1 which is also held by magnets.
Both of these optional parts will be kept safely until the end of the build.
#6 Posted : 01 May 2026 13:34:35
STAGE 32:
Right disc compartment.
Pic 1: Assemble 2 x discs using parts 32-2 and 32-3 as before.
Pic 2: Retrieve the disc holder 29B (outlined in grey) and fit it into the left wing as shown.
Fit the leading edge through the aperture first.
Pic 3: Fit the cover 32-1 in place and fix with 2 x A screws.
Pic 4: From the outside, clip the 4 x discs into the holder.
Pic 5: Fit the lower cover 30-4 (outlined in grey) in place.
It is held with magnets.
This page was generated in 1.056 seconds.
