Ferrari 330 P4 Official Build stages 81 - 86 Options
#1 Posted : 26 April 2026 13:06:53
STAGE 81:
Dashboard and frame.
Pic 1: Retrieve the unused parts from the previous stage.
Press-fit the gauge 80C into the surround 80B from behind.
Pic 2: Fit the assembly into the underside of the cowl 80D as shown.
Pic 3: Press-fit the assembly into the top of the dashboard 80A as shown.
Pic 4: Fit the gauges 81C, 81F and 81D into the surround 81E.
NOTE – These parts are a loose fit and will very probably fall out so a small amount of clear adhesive such as UHU might be advisable.
Pic 5: Press-fit the assembly onto the frame 80B.
Pic 6: View from the front.
Pic 7: Fit the assembly to the underside of the dashboard and fix with 2 x AP screws.
Pic 8: Fit the frame 81A in place as shown, noting the front bar locates under the gauge assembly.
Fix with 5 x AP screws
#2 Posted : 28 April 2026 14:52:22
STAGE 82A:
Dashboard and instruments.
Pic 1: Press-fit the ignition switch 82H into the dash panel 82A.
It will only fit one way.
Pic 2: Press-fit the 6 x 82D switches in place where shown.
They will only fit one way.
Fit the collar 82F onto the end of the switch 82G, and then fit the assembly into the top hole on the dashboard where shown.
Press-fit the choke knob 82E in place as shown.
Pic 3: Fit the gauge 82J into the surround 82L and then fit the assembly into the dashboard.
NOTE – This part is not a tight fit.
You may wish to use a little clear adhesive such as UHU.
Pic 4: Fit the steering column bracket 82B as shown and fix from behind with 2 x AP screws.
Pic 5: On the back of the dash panel, fit the LED holder and fix with 2 x AAP screws.
NOTE – Do not fully tighten these screws as the bracket will push the gauge out of the front of the dashboard.
#3 Posted : 28 April 2026 14:55:59
STAGE 82B:
Pic 6: Locate the air vent part 82L.
OPTIONAL DETAIL: To enhance the look of the part you could colour the vent holes black with a fine marker.
Pic 7: Press-fit the vent into the dash panel as shown.
Pic 8: Fit the switch labels in place where indicated.
There are two sets supplied and they fit in order from the top to the bottom.
Pic 9: Retrieve the assembly from the previous stage and fix the dashboard underneath with 3 x AM screws.
Pic 10: Retrieve the small LED panel 52C and fit it over the two pegs on the rear of the gauge panel as shown.
NOTE – This part is not a tight fit so you may be advised to use a small dot of adhesive on each peg to prevent the LED panel falling off when the model is complete.
Pic 11: Plug the LED’s into place behind the gauges as shown, and feed the other wire under the metal frame.
Pic 12: Store the assembly and unused parts safely for now.
#4 Posted : 29 April 2026 10:14:35
STAGE 83A:
Pipes, panels & tanks.
Pic 1: Locate the pipe parts 83A and 83B.
Pic 2: Fit them together and fix with 2 x AAP screws.
Pic 3: Retrieve the dashboard assembly and fit the pipe underneath as shown, (highlighted grey) fixing with 1 x AP screw.
Pic 4: Retrieve the steering wheel and column and fit it place under the dashboard.
Fit the bracket 82C and fix with 2 x AP screws.
Pic 5: Press-fit the air hose 83E in place as shown.
Pic 6: Retrieve the hose assembly 32C/D and fit it in place where shown.
Fix with 2 x AAP screws.
Pic 7: Retrieve hose 33E/F and fit it as shown, connecting one end to the hose 83A/B.
#5 Posted : 29 April 2026 10:17:28
STAGE 83B:
Pic 8: Press-fit the reservoir tank parts 83G and 83H together.
Pic 9: Fix the assembly to the panel 83F using 2 x AP screws.
Pic 10: Fix the assembly under the dashboard as shown using 2 x AP screws.
Pic 11: Cut the hose 83I into five pieces using the measurements shown.
Pic 12: Fit the 2 x 20mm pipes and the 115mm pipe to the ‘Y’ bracket 83J.
Pic 13: Fit the hoses to the tank assembly in the positions shown.
Pic 14: Push the switch 83D into the fuse panel 83C as indicated.
Pic 15: Store everything safely for now.
#6 Posted : 30 April 2026 10:11:38
STAGE 84:
Glass and lighting left door.
Pic 1: Locate the glass 84A and frame 84B.
They will clip-fit together.
Pic 2: Parts assembled.
Pic 3: Retrieve the door 10 and fit the window in place by locating the pins on the door in the holes in the lower glass – highlighted in yellow.
Fix the parts together with 1 x ACM screw.
Pic 4: Fit the door lights 84C, 84D and 84E as shown.
84D and 84E are actually identical.
When fitting these two lights, make sure the white part faces the number.
Pic 5: Fit the hinge parts 84F, 84G and 84H together as shown and fix from the outside with 2 x BM screws.
Pic 6: Fit the hinge to the door as indicated and fix with 2 x BM screws.
Pic 7: Store the assembly safely.
#7 Posted : 01 May 2026 16:55:29
STAGE 85:
Left door lining.
Pic 1: Press-fit the lock 85B into place on the lining 85A as shown.
Pic 2: Retrieve the door from the previous stage and fit the pull-strap 85C over the two posts as indicated.
Pic 3: Fit the door lining over the hinges on the door shell as indicated in yellow, then press-fix the parts firmly together.
Pic 4: Retrieve the left front panel assembly and remove the highlighted bracket indicated.
Do not lose the screws.
Pic 5: Bracket removed.
Pic 6: Fix the door hinges to the bracket where shown using 4 x AM screws.
Make sure the screws are fully tight so the door will not ‘wobble’.
Pic 7: Re-fit the bracket that you removed.
Pic 8: Retrieve the main car.
The front panel attached to the door hinges will fix onto the chassis frame where indicated.
Pic 9: Wiggle the panel into place and then turn the model upside down.
Fix the panel to the frame using 2 x AM screws.
Pic 10: With the car the right way up, close the door.
#8 Posted : 02 May 2026 12:57:33
STAGE 86:
Right door.
Pic 1: Locate the door parts 86A and 86B.
Pic 2: Fit part 86B in place on the end of the door inside, as indicated in yellow.
Fix with 1 x AM screw.
Pic 3: Store everything safely for now.
This page was generated in 0.320 seconds.
