World of Warcraft Lich King Pack 11 Options
#1 Posted : 04 May 2026 15:10:03
Issue 51
The Right Leg Outer Protection
Place the spine of the protection (51B) onto the right leg assembly from issue 50, pictures 2 and 3. Secure in place using 2 x LP screws, picture 4.
Place the fastening straps (51D and 51E) on the inner pegs securing each strap using 2 x SP screws as illustrated in picture 5.
Picture 6 shows the assembly complete for this issue.
#2 Posted : 06 May 2026 10:35:17
Issue 52
The Left Leg Inner Protection
Place the fastening straps (52B and 52C) on the inner pegs of the leg protection (52A), securing each strap using 2 x SP screws as illustrated in picture 2.
#3 Posted : 08 May 2026 09:58:32
Issue 53
The Left Leg Outer Protection
Insert the inner left leg protection with the fastening straps, issue 52, inside the left leg protection (53A) and secure in place using 2 x LP screws as shown in pictures 2 and 3.
Picture 4 shows the assembly complete for this issue.
#4 Posted : 08 May 2026 10:03:15
Issue 54
Place the spine of the protection (54B) onto the right leg assembly from issue 53, and secure in place using 2 x LP screws, pictures 2 and 3.
Place the fastening straps (54D and 54E) on the inner pegs securing each strap using 2 x SP screws as illustrated in picture 4.
Picture 5 shows the assembly complete for this issue.
#5 Posted : 10 May 2026 17:00:13
Issue 55
The Left Shoulder Joint
Insert the shaft (55F) into the base (55A), pictures 2 and 3. Place one of the springs (55H) into the spring stop (55G), then place the assembly into the base at the end where you fed the joint shaft in, pictures 4 and 5. Cover the end of the base with the shaft and spring in place with the shoulder joint cover and secure it in place using 2 x “OM” screws, pictures 6 and 7.
Feed the shaft pin (55I) into the left arm joint base (55B), picture 8, then into the joint assembly as shown in picture 9.
This next part is quite tricky and did take me some time to fit the spring into the left arm joint base.
Fit the other spring and place it on the joint locking rod (55E), picture 10. Now place the assembly into the joint arm base as shown in picture 11. Cover the assembly with the arm joint base cover (55C) securing it in place using 2 x HM screws, picture 12.
Place the nut (55J) onto the end of the shaft pin and tighten it up using the wrench, picture 13.
Picture 14 shows the complete assembly for this issue.
#6 Posted : 10 May 2026 17:04:53
Issue 56
take the assembly from the previous issue and place it into the upper left arm joint (56A) and secure it in place using 2 x KP screws as shown in picture 2.
This page was generated in 0.194 seconds.
