Red Bull RB19 Official build. Stages 63 - 68 Options
#1 Posted : 13 May 2026 16:19:27
STAGE 63:
Right rear wheel.
Pic 1: Retrieve the wheel rim from stage 61.
The tyre 63A will fit over the rim as shown with the yellow text on the same side as the red wheel rim.
Pic 2: Press the tyre into place on the rim.
Pic 3: Store everything safely for now.
#2 Posted : 14 May 2026 10:23:07
STAGE 64:
Tyre rack 2.
Pic 1: Push-fit the 8 x joints 64B onto the ends of the 4 x crossbars 64A.
Pic 2: Push-fit the crossbars onto one of the tyre rack end frames from stage 62. They are both the same.
Pic 3: Fit the other end frame in the same way.
#3 Posted : 15 May 2026 10:17:47
STAGE 65:
Right rear wheel 2.
Pic 1: Fit the wheel cover 65B into the cover 65A as shown and fix with 2 x A screws.
Pic 2: Press-fit the assembled cover into the front of the wheel from stage 63.
Pic 3: Retrieve the rear right suspension assembly from stage 61.
Pic 4: Fit the wheel to the hub and fix using the collar 60B first, then the long bolt 63B.
Store the assembly safely.
NOTE – During this build the wheels will all be fitted near the end of the build as they are very heavy and will place unnecessary strain on the model parts, particularly when later on, the model will be turned over many times.
#4 Posted : 16 May 2026 11:48:42
STAGE 66:
Tyre rack 2.
Pic 1: Peel the protective film from both sides of the panels 66A.
Pic 2: Press-fit the 8 x brackets 66B into the ends of the panels as shown.
Pic 3: Retrieve the tyre rack from stage 62 and clip one of the end panels in place as shown.
Pic 4: Fit the other end panel in the same way.
Store the tyre rack safely for now.
#5 Posted : 19 May 2026 10:57:10
STAGE 67:
Radiator cover.
Pic 1: Fix the bracket 67E to the shock absorber cover 67F with 1 x T screw from underneath.
Pic 2: Fit the rod 67D into the lower hole in the fairing 67C.
Pic 3: Fit the upper fairing 67A as shown, locating the pin in the side fairing in the hole at the end of 67A where indicated.
Pic 4: Fit the other side fairing 67B as shown.
Pic 5: Fix with 2 x T screws.
Pic 6: Fit the assembly to the box as shown.
Fix the other bracket 67E in place and fix with 1 x T screw from underneath.
Store safely for now.
#6 Posted : 21 May 2026 13:26:48
STAGE 68:
Rear body section.
Pic 1: Place the assembly from the previous stage up against the body section 68A.
Pic 2: Fit the right wheel assembly into the slots highlighted where shown.
Pic 3: Repeat with the left wheel assembly, noting that the fixing holes in the arms overlap inside the body.
Pic 4: Fix the arms as shown using 2 x A screws and 1 x U screw.
Pic 5: Position the fixing plate 68C over the ends of the two arms where shown and fix with 1 x A screw.
Pic 6: Turn the assembly over and fix the two arms indicated with 2 x E screws.
Pic 7: Fit the support bar 68B in place and fix with 2 x T screws.
Pic 8: Store the assembly safely for now.
This page was generated in 0.194 seconds.
