Ducati Desmosedici GP23 Issues 27 to 32 Options
#1 Posted : 13 May 2026 09:48:36
Issue 27
Retrieve the left frame from the last issue and place the left cover as shown in pictures 2 and 3. Turn the assembly over and secure it in place using 3 x AP screws, picture 4. Now fit the left conveyor using 2 x AP screws as shown in pictures 5 and 6.
Retrieve the engine assembly and fit the left frame section over the engine assembly and secure this in place using an AP screw and 3 x BM screws as shown in picture 7.
#2 Posted : 14 May 2026 10:42:34
Issue 28
Retrieve the right cover and position it on the right frame section as you did in the previous issue, picture 2. Turn the assembly over and secure it in place using 3 x AP screws, picture 3. Now fit the right conveyor using 2 x AP screws as shown in picture 4.
Retrieve the engine assembly and with the right side facing up, attach the anchor as illustrated in pictures 5 and 6.
Fit the right frame section over the engine assembly and secure this in place using 2 x AP screws as illustrated in picture 7. Fit an AM screw to secure the frame and anchor, picture 8, then fit another 4 AM screws at the steering head as shown in picture 9.
Picture 10 shows the complete assembly for this issue.
#3 Posted : 17 May 2026 17:19:08
Issue 29 Part 1
Take the cable and cut it into 9 parts as laid out below, picture 2.
E1-45mm
E2-170mm
E3-160mm
E4-220mm
E5-180mm
E6-220mm
E7-145mm
E8-250mm
E9-250mm
Tip: When unravelling the cable, place it in some hot water to take out any kinks.
Place the red connector onto the cable connection bracket using an AP screw, picture 3. Place E1-2-3 cables as illustrated in picture 4. Place cables E4-5 in the same way, picture 5, cables E6-7 as shown in picture 6 and finally cables E8-9 as shown in picture 7.
Take the cables E3-4-5 and bind them together using the tape supplied in the previous issue. Tape together cables E8-9, picture 8.
On the underside of the bracket place the yellow connector in place using an AP screw, picture 9. Note, the magazine says red connector instead of the yellow connector.
That completes part 1 of this issue
#4 Posted : 17 May 2026 17:21:08
Issue 29 Part 2
Feed the cables though the frame as illustrated in picture 10. Secure the bracket in place using 2 x AM screws, picture 11.
Continue to feed cables E2 and E7 through as shown in picture 12. Feed cables E3-4-5 as illustrated in picture 13, followed by cables E8-9, picture 14.
Finally, complete the assembly by placing the connector with cable to the intake box as shown in picture 15.
Picture 16 shows the assembly complete for this issue.
#5 Posted : 19 May 2026 10:16:49
Issue 30
Fit the control unit tray to the top of the air intake box, aligning the holes in the tray, then secure it in place using 2 x AP screws, picture 2.
Take the two elastic ties and place them into the tray by inserting the “T” shaped ends into the corresponding holes as shown in picture 3.
Next, carefully feed the control unit under the elastic ties, fitting it inside the tray, picture 4.
Now take the connectors, starting with the red connector and push fit them in place in the order of red, yellow and blue, with one end into the control box and the pipe end into the cable connection bracket as illustrated in picture 5.
#6 Posted : 20 May 2026 19:19:20
Issue 31
Get a little warm water in a suitable container and prepare two of the carbon decals. Place one of the decals in the water for around 30 seconds, then using a pair of tweezers take the decal of the paper and wrap it around the front of the fork slider as shown in picture 2. Carefully dab any excess water off using a soft paper towel.
Repeat the process with the second decal, placing it on the fork slider as indicated in picture 3.
Allow the decals to dry for at least two hours before moving onto the next stage.
Picture 4 shows the complete assembly for this issue.
#7 Posted : 22 May 2026 10:12:15
Issue 32
Retrieve the fork slider and insert the oil seal to the bottom of the fork slider, picture 2. To do this carefully insert the seal and using the fork tube push the seal down into the slider as shown in picture 3.
Once the oil seal is in place take out the fork tube and insert the oil seal ring, picture 4.
Place the spring onto the fork tube as illustrated in picture 5, then place the tube into the slider, picture 6.
Making sure the slots on the tube correspond to the two side holes on the slider, insert an AM screw on either side to hold the tube in place, picture 7.
This page was generated in 0.222 seconds.
