Toyota Supra F+F Issues 63 - 68 Options
#1 Posted : 19 May 2026 10:15:16
STAGE 63:
Seats 1.
Pic 1: Stick 2 x self-adhesive pads 63C to the sponge seat inner 63B as shown.
Pic 2: Peel the backing from the pads and stick the sponge to the inside of the seat 63A as shown.
Pic 3: Store the seat part safely for now.
#2 Posted : 20 May 2026 09:49:03
STAGE 64:
Seats 2.
Pic 1: Stick 2 x self-adhesive pads 64C to the sponge seat inner 64B as shown.
Pic 2: Peel the backing from the pads and stick the sponge to the inside of the seat 64A as shown.
#3 Posted : 21 May 2026 13:32:31
STAGE 65:
Seats 3.
Pic 1: The seat inner back 65A will fit inside the seat back from stage 63.
Pic 2: Fitting 65A into 63A is extremely fiddly as the 5 x rubber tabs inside the seat back are in the way when fitting the inner back.
The tabs need to be above the inner back, as well as the seat back hinge posts indicated need to protrude through the holes in the lower sides.
When the parts are assembled, fix with 5 x EP screws.
Pic 3: Fit the seat headrest inner 65C in the same way and fix with 2 x EP screws.
Pic 4: Press the seat back 65E into place.
Pic 5: Press the headrest back 65D into place.
Pic 6: Press the front trim 65B into place.
Pic 7: Repeat all the above with the other seat back.
Store both assemblies safely.
#4 Posted : 22 May 2026 10:36:19
STAGE 66:
Seats 4.
Pic 1: Fix 2 x self-adhesive tabs 66C to the inside of the seat base 66A as shown.
You will find it easier than trying to stick them to the foam pad 66B.
Pic 2: Peel the backing from the tabs and stick the foam 66B in place where indicated.
Pic 3: Store safely for now.
#5 Posted : 26 May 2026 14:07:24
STAGE 67:
Seats 5.
Pic 1: Retrieve the seat base from the previous stage.
The lower support 67A will fit inside, under the 5 x rubber tabs.
Pic 2: Fit the parts together and fix with 5 x EP screws.
Pic 3: Fit the assembly into the seat back from stage 63.
The hinge-pins on the lower back will locate in the holes in the seat base support where indicated.
Pic 4: Fix the parts with 2 x DP screws.
Pic 5: Slide the seat runners 67C-L and 67D-R into the slots in the frame 67B.
They will only fit one way.
Pic 6: Fix the assembly to the underside of the seat as shown and fix with 2 x MP screws.
Pic 7: Store safely for now
#6 Posted : 12 June 2026 12:25:33
STAGE 68:
Seats 6.
Pic 1: Fit the seat belt catch 68B to the side of the base 68A as shown.
Pic 2: Fit the handle 68C on the other side of the seat base.
Pic 3: Fix the adjuster handle 68D to the front corner of the base using 1 x AP screw.
Pic 4: Retrieve the seat and fix the frame underneath using 2 x AP screws.
Pic 5: Store the seat safely for now.
This page was generated in 0.533 seconds.
