 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,860 Points: 17,732 Location: ipswich
STAGE 6:
Front left brake.
Pic 1: Fit the disc parts 6A and 6B together.
Pic 2: Parts assembled.
Pic 3: Fit the disc centre 6E and fix with 3 x NP screws.
Pic 4: Fix the caliper parts 6C and 6D together with 2 x KM screws.
Pic 5: Fix the bracket 6F to the hub 6I with 2 x KM screws.
Pic 6: Press-fit the cooling duct parts 6G and 6H together.
Pic 7: Parts assembled.
Pic 8: Fit the connector 6J to the hub as shown.
Pic 9: Fit the air duct to the hub. The parts will only fit one way. Fix from underneath with 2 x CP screws.
Pic 10: Fit the disc to the hub.
Pic 11: Fit the caliper as shown and fix with 2 x KM screws.
Store the assembly safely.roymattblack attached the following image(s):
STAGE 7:
Rear wheel.
Pic 1: Place the tyre 7A so that the bar code and symbol indicated is facing upwards.
Pic 2: Fit the outer rim 7B in place.
Pic 3: Fit the rear rim in place so that the four screw fixing points are in line on both parts of the rim Fix with 4 x BM screws.
Store the wheel safely.
STAGE 8:
Front right brake.
Pic 1: Fit the disc parts 8A and 8B together.
Pic 3: Fit the disc centre 8E and fix with 3 x NP screws.
Pic 4: Fix the caliper parts 8C and 8D together with 2 x KM screws.
Pic 5: Fix the bracket 8F to the hub 8I with 2 x KM screws.
Pic 6: Press-fit the cooling duct parts 8G and 8H together.
Pic 8: Fit the connector 8J to the hub as shown.
