Peugeot 205 Dakar Turbo Official Build STAGES 81 - 86 Options
#1 Posted : 20 May 2026 10:29:18
STAGE 81:
Front crossbar.
Pic 1: Slide the bracket 81F over the strap 81D.
Pic 2: Stick one of the self-adhesive tabs 81H to the end of the strap.
Pic 3: Remove the backing from the tab and fold the strap over the bracket as shown.
Pic 4: Repeat with the other bracket 81F at the other end of the strap.
Pic 5: Stick another tab 81H in the centre of the strap and position the hook 81G as shown.
Pic 6: Remove the backing and fold the strap in half, trapping the bracket in place.
Pic 7: Retrieve the main assembly and press-fit the two end brackets into the holes in the front floor where indicated.
Make sure the central hook on the strap is facing down.
Pic 8: Retrieve the spare wheel from the previous stage and fit it in place.
Secure it with the front strap just fitted, and the strap from the bulkhead just behind the spare wheel.
Pic 9: Assemble the crossbar 81A and end brackets 81C as shown and fix with 1 x AOM screw in each.
Pic 10: Fit the assembly into the front of the car as shown and fix with 2 x AM screws.
Pic 11: Fit the covers 81E and 81B in place and fix from underneath with 2 x AM screws in each.
NOTE: This is extremely fiddly as access to the fixing holes is very limited.
You may be advised to glue the covers in place before turning the model over to fit the screws.
#2 Posted : 21 May 2026 14:50:53
STAGE 82:
Tinted window.
Pic 1: This stage gives you the option to fit tinted windows.
This is at your discretion.
The clear windows will be kept in this build so the interior is easier to see.
Assemble the tinted parts 82D, 82E and 82F as shown if you wish to use them.
Pic 2: Retrieve the door from stage 4.
Pic 3: Remove the screws holding the outer cover highlighted.
Do not lose the screws as the outer cover will be fitted to the tinted windows.
Pic 4: Whichever window option you choose, the 2 x screws currently holding the window in place are replaced with 2 x TM screws.
Pic 5: Fix the hinges 82B to the door using 2 x CM screws.
Pic 6: Fix the strap 82C to the inner frame 82A with 1 x ABP screw.
Pic 7: Store the parts safely for now.
#3 Posted : 22 May 2026 13:27:34
STAGE 83A:
Left door interior.
Pic 1: Stick a self-adhesive tab 83J to the end of the shortest strap, 83F.
Pic 2: Peel the backing from the tab and fold the strap over as shown.
Pic 3: Using a sharp point, make a small hole in the end of the strap.
Pic 4: Insert a KP screw.
Pic 5: Fix the strap as shown to the panel 83A.
Pic 6: Pass the cord 83G through the strap and tie it in place as indicated.
Pic 7: Pass the other end of the cord through the hole in the end of the panel and tie a knot.
Cut off any excess cord.
#4 Posted : 22 May 2026 13:30:00
STAGE 83B:
Pic 8: Fix a tab 83J to the end of the medium length strap 83B and pass a buckle 83D over it.
Pic 9: Peel the backing from the tab and fold the strap over the buckle as shown.
Pic 10: Stick anther tab 83J to the other end of the strap and stick it to the top of the toolbox 83H where indicated.
Pic 11: Fix the toolbox to the panel 83A using 1 x KP screw.
Pic 12: Fit the front of the toolbox 83I in place.
Pic 13: Retrieve the inner frame 82A and fit the toolbox assembly in place from the inside.
Fix with 3 x AP screws.
#5 Posted : 22 May 2026 13:32:09
STAGE 83C:
Pic 14: Pass the longer strap 83C through the buckle on the toolbox strap as shown.
Pic 15: Fit a buckle 83E on each end of the strap and then add a tab 83J.
Pic 16: Peel the backing from the tabs and fold the straps over the buckles.
Pic 17: Fix the ends of the straps to the door frame as shown with 2 x KP screws.
Pic 18: Retrieve the door 4A and fit the inner assembly in place.
Make sure you locate the pins on the glazing in the holes in the upper inside frame.
Fix the parts together with 5 x BM screws.
Pic 19: Fit the mirror 4B to the door and fix with 1 x AP screw from the inside.
Store safely for now.
#6 Posted : 27 May 2026 12:16:18
STAGE 84:
Right door.
Pic 1: Fix the 2 x hinges 84B to the inside front of the door 84A as shown, using 2 x CM screws.
The hinges will only fit properly one way.
Make sure the screws are fully tight so the hinges cannot ‘wobble’.
Pic 2: Store safely for now.
#7 Posted : 28 May 2026 14:14:16
STAGE 85:
Right door interior.
Pic 1: Attach a self-adhesive pad 85D to one end of the strap 85B.
Pic 2: Peel off the backing and fold the strap over as shown.
Pic 3: Using a pointed tool or a small punch, make a hole in the strap where indicated.
Pic 4: Fix the strap to the door frame 85A where shown using 1 x KP screw.
Pic 5: Feed the cord 85C through one end of the door, through the strap 85B and then through the hole in the other end of the door.
Tie a knot in both ends of the cord.
Trim any excess cord off.
Pic 6: Store safely for now.
#8 Posted : 29 May 2026 11:45:34
STAGE 86:
Right door window.
Pic 1: As with the other door, you have the option to fit tinted or clear windows.
For the tinted window, assemble parts 86H, 86I and 86J as shown.
Pic 2: For the clear window, use parts 86A, 86B and 86C.
Pic 3: For either the tinted or clear window, fit the outer shield 86D as shown and fix with 2 x KP screws.
Pic 4: Retrieve the door shell 84A and fit the window assembly in place from the outside, with the lower part of the window on the inside.
Fix with 2 x TM screws.
Pic 5: Retrieve the inner door assembly 85A and fit it in place.
Fix with 5 x BM screws.
Pic 6: Peel the backing from the mirror 86F and stick it in place on the mirror body 86E.
Pic 7: Fit the mirror to the door and fix from the other side with 1 x AP screw.
Pic 8: Fix the retaining strap 86G to the inner panel with 1 x ABP screw.
This page was generated in 0.253 seconds.
