Lamborghini Revuelto official build Stages 9 - 14 Options
#1 Posted : 31 May 2026 12:09:47
STAGE 9:
Gearbox.
Pic 1: Fit the connector 9A to the gearbox 9B as shown and fix with 3 x F screws.
Pic 2: Fit the pump 9C to the end of the gearbox where indicated and fix with 3 x F screws.
Pic 3: Press the filter 9D into the lower side of the gearbox.
It will only fit one way.
Store safely for now.
#2 Posted : 02 June 2026 15:17:20
STAGE 10:
Hybrid motor.
Pic 1: Motor part 10A will fit face down on part 10B.
Pic 2: Fix the parts with 3 x F screws.
Pic 3: Fit the housing 10C to the assembly as shown and fix with 1 x F screw.
Pic 4: Retrieve the assembly from stage 9 and fit the motor in place as indicated.
Fix on the inside with 2 x F screws.
Pic 5: Store all parts safely for now.
#3 Posted : 05 June 2026 12:10:32
STAGE 11A:
Left radiator and lights.
Pic 1: The radiator grille 11A will fit on top of the radiator 11B.
Pic 2: Fix with 2 x B screws.
Pic 3: Retrieve the left light assembly from stage 1.
It will fit onto the back of the radiator.
Pic 4: Fix the parts together as shown and fix with 3 x A screws.
Pic 5: Retrieve the front panel 2B and the light 2C.
Pic 6: Wrap the self-adhesive ‘V’ label around the plug end of the wires.
#4 Posted : 05 June 2026 12:16:42
STAGE 11B:
Pic 7: Fix the light to the rear of the front panel with 3 x A screws.
The light will only fit one way.
Pic 8: Fix the radiator support frame 11D as shown using 2 x A screws.
The frame will only fit one way.
Pic 9: Fit the small end panel 11E as indicated and fix with 2 x A screws.
Pic 10: Retrieve the left light glass from Stage 1 and fit it into the front panel from the inside.
Pic 11: Fit the radiator and lamp assembly in place, trapping the glass in its location.
Fix with 2 x A screws.
Pic 12: Wrap the self-adhesive R label around the plug end of the LED’s 11F.
Pic 13: Fit the LED’s into the back of the headlights.
They will only fit one way.
Fix in place with 4 x A screws.
Pic 14: Run both sets of wires across the inside of the panel, between the two screw posts.
Fit a cable grip 11H in place and fix with 2 x A screws.
Keep the other cable grip for later use.
#5 Posted : 07 June 2026 11:09:48
STAGE 12A:
Pic 1: The radiator grille 12A will fit on top of the radiator 12B.
Pic 2: Retrieve the left light assembly from stage 1.
Pic 3: Locate the light 2C.
Wrap the self-adhesive ‘U’ label around the plug end of the wires.
Pic 4: Fix the light to the rear of the front panel with 3 x A screws.
Pic 5: Fix the radiator support frame 12D as shown using 2 x A screws.
Pic 6: Fit the small end panel 12E as indicated and fix with 2 x A screws.
#6 Posted : 07 June 2026 11:13:10
STAGE 12B:
Pic 7: Retrieve the right light glass from Stage 1 and fit it into the front panel from the inside.
Pic 8: Fit the radiator and lamp assembly in place, trapping the glass in its location.
Pic 9: Fit the LED’s into the back of the headlights.
Pic 10: Wrap the self-adhesive ‘Q’ label around the plug end of the LED’s 12F.
Pic 11: Run both sets of wires across the inside of the panel, between the two screw posts.
Fit a cable grip 12H in place and fix with 2 x A screws.
12: Run wires from the other light assembly across the inside of the panel, between the two screw central posts.
Pic 13: Store the assembly safely for now.
#7 Posted : 09 June 2026 10:41:47
STAGE 13:
Oil cooler.
Pic 1: Retrieve the engine assembly and locate the oil filter plate 13A.
It will fit on the side of the engine where indicated.
Pic 2: Fit the plate as shown and fix with 3 x E screws.
Pic 3: Fit the oil cooler 13B to the plate and fix with 3 x F screws.
Pic 4: Push the 50mm x 3.5mm pipe 13D into the fitting 13C.
Pic 5: Fit the assembly to the engine as shown.
Pic 6: Fix the engine mount plate 13E to the side of the engine with 1 x F screw.
Pic 7: Push the thick tube 13H into the fitting 13F and the thinner tube 13G into the other end.
Pic 8: Fit the thinner tube into the location shown.
Pic 9: Fit the long tube 13I into the side of the engine where indicated.
#8 Posted : 11 June 2026 15:22:36
STAGE 14:
Left and right cylinder heads.
Pic 1: Fit the connector 14A as shown with the two legs facing in on the engine top.
Pic 2: Fit the right cylinder head 14B as shown so the leg on the fitting goes into the hole indicated.
Pic 3: Fix with 3 x E screws.
Pic 4: Fit the left cylinder head 14C as shown so the leg on the fitting goes into the hole indicated.
Pic 5: Fix with 3 x E screws.
Store the assembly safely.
This page was generated in 0.808 seconds.
