 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
STAGE 87:
Right door window and hinges.
Pic 1: Press-fit the window parts 87A and 87B together. The parts will only fit one way.
Pic 2: Retrieve the door from the previous stage and fit the window in place on the inside as shown. Fix with 1 x ACM screw.
Pic 3: Retrieve the hinge bracket 86C from the previous stage and locate the hinges 87D and 87E.
Pic 4: Fit the top hinge 87D in the position shown and fix with 1 x BM screw. Make sure the screw is fully tightened or it will foul the inner door panel later on.
Pic 5: Fit the bottom hinge 87E in the position shown and fix with 1 x BM screw. Make sure the screw is fully tightened or it will foul the inner door panel later on.
Pic 6: Fix the hinge assembly inside the door 86A using 2 x BM screws.
Store safely for now.roymattblack attached the following image(s):
STAGE 88A:
Right door lining and fitting.
Pic 1: Press-fit the lock 88B into the end of the door lining 88A. It will only fit one way.
Pic 2: Retrieve the door 86A and fit the strap 88C over the two posts as indicated.
Pic 3: Wriggle the door lining over the hinges and press it firmly into place on the door shell.
Pic 4: Retrieve the partition assembly 79D and remove the air intake support indicated. Do not lose the screws.
Pic 5: Part removed.
Pic 6: Fix the door in place as shown using 4 x AM screws.roymattblack attached the following image(s):
STAGE 88B:
Pic 7: Fit the door and partition in place as shown making sure the bottom of the silver partition is sitting flat on the body frame.
Pic 8: Holding the door in place, carefully turn the model over and fix the partition using 2 x AM screws.
Pic 9: Re-fit the air pipe support previously removed.
Pic 10: Remove and discard the pipe indicated.
Pic 11: Fit the new pipe 88D and feed it through the front sidewall. Connect it to the brake caliper.
Pic 12: Route the other long pipe on the gold fitting through the front sidewall as indicated and connect it to the brake caliper.
STAGE 89A:
Central body.
NOTE: Several of the stages here are very fiddly and awkward. Take your time and be patient.
Pic 1: Retrieve the dashboard assembly and remove the steering column support bracket. Do not lose the part or screws.
Pic 2: Connect the fuse panel 83C to the 120mm tube coming from the central seat tunnel and the 75mm tube attached to the front frame.
Pic 3: Attach the 80mm tube from the seat tunnel to the pin indicated under the dashboard assembly.
Pic 4: Connect the steering column to the universal joint as shown and fix with 1 x AM screw from above and 1 x AM screw underneath.
Pic 5: Connect the hose from the right reservoir to the front pin on the cylinder as shown.roymattblack attached the following image(s):
STAGE 89B:
Pic 6: This step is very fiddly.
Wriggle the dashboard into place making sure the two air hoses (shown in the next pic) pass underneath the frame cross-bar. You may find it easier to temporarily remove the screws holding the longer hose to the dashboard so it can move. When in place, fix the dash with 1 x AM screw on each side.
Pic 7: Shows where the two air hoses must go.
Pic 8: With the car upside down, fix the centre of the dash to the main frame where shown using 2 x AM screws.
Pic 9: Re-fit the steering wheel support bracket.
Pic 10: From underneath, connect the ‘G’ plug and socket.
Pic 11: With the car upside down, fit the fuse panel in place where shown and fix with 2 x AP screws.
Pic 12: Connect the hoses highlighted in red and yellow to the pins on the left cylinders.
Store the model and unused parts safely for now.
STAGE 90A:
Windscreen and fittings.
Pic 1: Retrieve the central body and remove the support bar by unscrewing the 1 x screw in each end.
Pic 2: Fix the mirror 89C to the holder 89B as shown.
Pic 3: Fit the mirror to the pin on the window frame where indicated.
Pic 4: Locate the filler cap parts 90E, 90F and 90G.
Pic 5: Fit the parts together as shown and fix both ends with 4 x MP screws, 2 in each end.
Pic 6: Press-fit the cap seal 90H in the cap lid.
STAGE 90B:
Pic 7: Fit the assembly into the holder 90H. It will only fit one way.
Pic 8: Fix from the other side with 2 x KP screws.
Pic 9: Fit the fuel cover flap 90C inside the body panel as shown.
Pic 10: Fix the fuel cap assembly in place and fix with 3 x AM screws.
Pic 11: Pass the wire 90I through the holes in the tabs on the cover and body. Twist the wire to keep it in place.
Pic 12: Fit the screen 90A into the body panel. Start at the lower front, then the two sides and finally the top centre. Take care here.
Pic 13: Fit the wiper to the body as shown and fix from underneath with 1 x KP screw.
Store the assembly safely for now.roymattblack attached the following image(s):
STAGE 91:
Front body.
Pic 1: Assemble the fuel cap parts 91D, 91E and 91F as shown and fix with 2 x MP screws in each end.
Pic 2: Press-fit the cap seal 91G in place in the lid.
Pic 3: Fit the assembly into the holder 91C and fix from underneath with 2 x KP screws.
Pic 4: Retrieve the front body and fit the fuel flap 91B from the inside.
Pic 5: Fit the filler assembly in place and fix with 3 x AM screws.
Pic 6: Fit the wire 91H through the tabs as shown and twist to keep it in place.
Pic 7: Fit the front body to the car and fix with 1 x AM screw where indicated.
Pic 8: With the car upside down, fit 1 x AM screw next to the fuel filler where shown.
Pic 9: Fit another AM screw in the same place on the opposite side.
Pic 10: Fit the cover 91A in place and fix with 2 x TM screws.
Store the model safely.
STAGE 92:
Front left bulkhead.
Pic 1: Press-fit the tank pipe fitting 92B into the bulkhead 92A as shown.
Pic 2: Retrieve the car assembly and carefully place it upside down on a soft surface so you have access to the front left side. Fit the bulkhead in place and fix with 2 x AM screws.
Pic 3: Press-fit the drain hose 98C as shown making sure the hose connects in both locations indicated.
Pic 4: The printed instructions tell you that you can now fit the left front wheel. To do so, fit the front disc 2E/F to the hub as shown.
Pic 5: Retrieve the left front wheel. Note that the central shaft has a key on it that will locate in the slot on the disc.
Pic 6: Fit the wheel in place making sure the key and slot are in line. Add the washer 92E, then fix with 1 x FM screw.
Pic 7: Press-fit the centre cap 2D in place.
NOTE: The wheels are not actually being fitted at this stage as they are heavy and the model still needs to be turned over several times in future stages. This is at the builder’s discretion.
Store the model and any unused parts safely labelled for now.roymattblack attached the following image(s):
