 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
STAGE 81:
Driver’s seat.
Pic 1: Twist the end of the buckle 81C at right-angles as shown.
Pic 2: Fix an adhesive tab 81B to one end of the strap 81D. Slide the buckle 81C onto the strap as indicated.
Pic 3: Peel the backing from the tab and fold the strap over the buckle.
Pic 4: Fix another tab 81B to the other end of the strap.
Pic 5: Feed the strap through the slot in the base of the seat 81A.
Pic 6: Turn the seat over, remove the backing from the tab and stick the strap down where indicated.
Pic 7: Store safely for now.
STAGE 82:
Driver’s seat 2.
Pic 1: Fit the support bracket 82F to the back of the seat panel 82A as shown and fix from the other side with 2 x XP screws.
Pic 2: Fit the seat face 81A from the previous stage.
Pic 3: Check that the top tabs fit over the frame where indicated.
Pic 4: Fix the seat parts together with 3 x TP screws. Make sure the lower tab is located properly where shown.
Pic 5: Fix the other side together with 3 x TP screws. Make sure the lower tab is located properly where shown.
Pic 6: Fix the lower front with 3 x TP screws.
Pic 7: Fit the head protection brackets 82B and 82E as indicated and fix with 1 x TP screw in each.
Pic 8: Fit the head protection pads 82C and 82D where shown.
Pic 9: Store the seat for now.
STAGE 83:
Driver’s seat 3.
Pic 1: Fit the side supports 83B and 83C to the seat back where shown and fix with 2 x TP screws in each.
Pic 2: Slide the support pads 83A and 83D over the supports as shown. The text goes to the outside, upwards.
Pic 3: Store safely for now.
STAGE 84:
Driver’s seat 4.
Pic 1: Fix the support bracket 84A to the base of the seat 82A using 2 x AM screws.
Pic 2: Fix the rear support 82C to the base of the seat as shown using 2 x EP screws.
Pic 3: gently flex the frame 84B so you can fit the seat between the side rails. Pay attention to the orientation of the seat and frame. Fix on one side with 2 x FM screws.
Pic 4: Fix the other side in the same way with 2 x FM screws. Store the seat safely for now.
STAGE 85A:
Safety harness 1.
Pic 1: Fold the end of the catch 85D as shown.
Pic 2: Stick one of the tabs 85F onto one end of the strap 85A.
Pic 3: Pass the strap through the side slot in the bracket as indicated.
Pic 4: Peel the backing from the tab and fold the end of the strap over.
Pic 5: Pass strap 85C through the other slot in the belt catch. Make sure the text is facing up, away from the bend in the catch.
Pic 6: Stick one of the tabs 85F onto one end of the strap 85C.
Pic 7: Peel the backing from the tab and fold the end of the strap over.
STAGE 85B:
Pic 8: Note the two fold lines on the other catch 85E.
Pic 9: Fold the catch over on itself as shown.
Pic 10: Pass strap 85A through the catch as shown and stick a tab 85F on the end.
Pic 11: Peel the backing from the tab and fold the end of the strap over.
Pic 12: Pass strap 85C through the other slot in the belt catch with the text facing up.
Pic 13: Stick one of the tabs 85F onto the end of the strap 85C.
Pic 14: Peel the backing from the tab and fold the end of the strap over.
Pic 15: Store all parts safely for now.
STAGE 86A:
Safety harness 2.
Pic 1: Fit the vent duct 86C to the back of the seat.
Pic 2: Retrieve the right strap assembly and fit the buckle 86A as shown.
Pic 3: Turn the strap over and fit a self-adhesive tab 86D to the end.
Pic 4: Peel the backing off and fold the strap over . Pic 5: Fit the floor fixing 86B over the strap 85B, then fit a tab 86D on the end as shown.
Pic 6: Fold the strap over as before.
STAGE 85B:
Pic 7: Fit the strap 85B into the buckle 86A as shown.
Pic 8: Turn the strap over and fit a tab 86D.
Pic 9: Fold the strap over as before.
Pic 10: Retrieve the left strap assembly and fit a buckle 86A as before.
Pic 11: Fix the buckle with a tab 86D.
Pic 12: Fit a floor fixing 86B to the end of the long strap.
Pic 13: Fit a long strap 85B to the buckle as shown.
Pic 14: Fix the strap as before.
STAGE 86C:
Pic 15: Fix the right strap assembly to the floor near the tunnel with 1 x XP screw.
Pic 16: Fix the left strap assembly to the floor near the side with 1 x XP screw.
Pic 17: With the straps out of the way, fit the seat to the floor.
Pic 18: Fix from underneath with 4 x AM screws.
Pic 19: Pass the two long straps through the slots in the back of the seat.
Pic 20: Add 2 x fixing brackets 86B using tabs 86D as before.
Pic 21: Fix the straps to the seat back plate using 2 x XP screws.
Pic 22: Fit the seat buckle parts together.
The two side straps first, then the seat strap.
Store safely for now.roymattblack attached the following image(s):
