Peugeot 205 Dakar Turbo Official Build STAGES 87 - 92 Options
#1 Posted : 12 June 2026 11:31:53
STAGE 87:
Main body.
Pic 1: Remove the two retaining bars indicated by removing the screws highlighted in red.
Discard the bars and screws.
Pic 2: Bars removed.
Pic 3: Press-fit the 3 x plugs 87B into the holes in the roof where shown.
NOTE – The parts are not a tight fit.
You may wish to use a dot of adhesive but this is at the builder’s discretion.
Save the assembly safely.
#2 Posted : 15 June 2026 10:53:31
STAGE 88:
Windscreen.
Pic 1: Peel the backing from the mirror 88E.
It will stick in place on the frame 88D.
Pic 2: Parts assembled.
Pic 3: Carefully press the mirror stalk into the hole on the inside top of the screen 88A.
Pic 4: Stick one of the sticky tabs 88F to the front clear face of the angled legs on each side of the lower screen as shown.
Pic 5: Peel the backing from the tabs and fix an angled bracket 88C to each.
Make sure the screw holes are in line with those on the plastic legs.
Pic 6: Fit the screen legs into the body aperture first and then carefully press the two clips on the upper screen corners into place on the body.
Pic 7: From the inside, fix the lower screen with 2 x AM screws.
Pic 8: At the outer top of the screen, fix the 2 x brackets 88B with 1 x RM screw in each.
Store safely for now.
#3 Posted : 17 June 2026 10:08:20
STAGE 89:
Roof lights.
Pic 1: Press-fit the 2 x lights 89B into the holder 89C.
Pic 2: Fit the lights through the two holes in the body roof from the inside.
Fix with 2 x AHM screws.
Pic 3: Lights fitted.
Pic 4: Fit the inner roof frame 89A and fix with 6 x TM screws.
The frame will only fit one way.
Store the assembly safely.
#4 Posted : 19 June 2026 10:07:23
STAGE 90:
Side panels.
Pic 1: Fit the handle 90E to the filler cap 90B as shown.
Take great care not to break the tiny locating pins on the handle.
Pic 2: Press-fit the assembly into the cap base 90C.
Pic 3: Fit the assembly into the rear of the side panel 90A.
Pic 4: Fix from behind with 2 x AM screws.
Pic 5: Retrieve the main body and fit the side panel as shown.
Pic 6: Fix from the inside with 4 x AM screws.
Pic 7: Fit the other side panel 90B on the other side.
Pic 8: Fix from the inside with 4 x AM screws.
Store the body safely.
#5 Posted : 23 June 2026 17:01:34
STAGE 91:
Lower left rear panel.
Pic 1: Bend the 3 x tabs on the edge of the grille 91D at an angle of approx. 70 degrees.
Pic 2: Retrieve the bonnet from stage 1 and fit the grille inside as shown.
Fix with 3 x QM screws.
Pic 3: Fit the grille 91B into the rear of the panel 91A.
The narrow end of the grill goes through the opening to the outside of the panel.
Pic 4: From the outside, fix with 2 x QM screws.
Pic 5: Fix the air intake 91C in place as shown using 4 x AM screws.
Pic 6: Retrieve the main body and fit the assembled panel in place as indicated.
Pic 7: Fix from the inside with 4 x AM screws.
#6 Posted : 26 June 2026 10:02:55
STAGE 92:
Lower right rear panel.
Pic 1: Fit the grille 92B into the rear of the panel 92A.
Pic 2: Fix from the other side with 2 x QM screws.
Pic 3: Fit the right air intake parts 92C and 92D together and fix with 2 x AP screws.
Pic 4: Fit the assembly to the inside of the side panel and fix with 3 x AM screws.
Pic 5: Retrieve the main body and fit the side panel in place as shown.
Pic 7: Retrieve the main car assembly and locate the red projection on the right side just behind the engine.
Wiggle the silver intake connector 92F in place as shown.
NOTE – This is quite fiddly.
Pic 8: Fit the other half of the connector 92E in place and fix the parts together with 1 x AP screw.
NOTE – This is also fiddly.
This page was generated in 0.256 seconds.
