Ferrari F1-2000 Official build Stages 9 - 14 Options
#1 Posted : 15 June 2026 14:03:25
STAGE 9:
Rear left brake.
Pic 1: Fit the bracket 9E to the hub 9D and fix with 2 x KM screws.
Pic 2: Fit the flange 9G to the hub and fix with 1 x KP screw.
Pic 3: Fix the clip 9B to the caliper 9F as shown using 1 x KM screw.
Pic 4: Locate the disc parts 9A and 9B.
They will fit together face to face.
Pic 5: Parts assembled.
Pic 6: Fix the disc centre 8E using 3 x NP screws.
Pic 7: Fit the assembled disc over the shaft on the hub as shown.
Pic 8: Fix the caliper to the side of the assembly using 2 x KP screws.
Pic 9: Fix the cooling plate 9A to the back of the hub with 2 x KM screws.
Pic 10: Press-fit the two inner pins on the cover 9C into the locating holes in the cooling plate.
Store safely for now.
#2 Posted : 17 June 2026 10:13:00
STAGE 10:
Rear right brake.
Pic 1: Fit the bracket 10E to the hub 10D and fix with 2 x KM screws.
Pic 2: Fit the flange 10G to the hub and fix with 1 x KP screw.
Pic 3: Fix the clip 10B to the caliper 10F as shown using 1 x KM screw.
Pic 4: Locate the disc parts 10A and 10B.
Pic 9: Fix the cooling plate 10A to the back of the hub with 2 x KM screws.
Pic 10: Press-fit the two inner pins on the cover 10C into the locating holes in the cooling plate.
#3 Posted : 19 June 2026 10:12:43
STAGE 11:
Engine distributor.
Pic 1: Locate the distributor cover parts 11A and 11B.
11B will press-fit onto 11A where shown.
Pic 2: Parts assembled.
#4 Posted : 24 June 2026 12:47:42
STAGE 12:
Engine parts.
Pic 1: Retrieve the assembly from the previous stage.
The side plate 12A will fit where indicated.
Pic 3: Press-fit the end cover 12C onto the pump 12B.
Pic 4: Fit the pump to the plate where shown.
It will only fit one way.
Pic 5: Fix from the other side with 1 x CP screw.
#5 Posted : 26 June 2026 10:07:55
STAGE 13:
Engine 3.
Pic 1: The upper engine part 13A and the connector 13B have ‘key’ fittings circled.
These parts will fit together. They cannot be assembled incorrectly.
Pic 2: Fit the parts together and fix using 2 x CM screws.
#6 Posted : 29 June 2026 11:54:17
STAGE 14:
Engine 4.
Pic 1: The left engine block 14A and the connector 14B will fit together as shown.
The smooth flat face is outwards.
Pic 2: Fit the parts together and fix using 2 x EM screws.
This page was generated in 0.680 seconds.
