World of Warcraft Lich King Pack 13 Options
#1 Posted : 30 June 2026 10:12:54
Issue 63
The Upper Structure of the Left Arm
Retrieve the body assembly and place the structure of the left arm onto the upper structure of the arm and secure in place using 4 x KP screws, picture 2 and 3.
Picture 4 shows the complete assembly for this issue.
#2 Posted : 01 July 2026 10:07:37
Issue 64
Breeches
Slip the breeches over the figures legs making sure you insert the four leg pegs, picture 2. Fasten the waist using the Velcro, picture 3.
#3 Posted : 02 July 2026 10:24:04
Issue 65
Chainmail Chausses
Slide the chausses over the figures legs making sure you insert the four leg pegs, picture 2.
Pull the chainmail chausses to the waistline and secure them in place using 5 x TP screws as shown in picture 3. You will need to pass them through the edge of the chainmail to engage them with the structure. Now place 6 more TP screws to the rear as illustrated in picture 4.
#4 Posted : 03 July 2026 10:07:45
Issue 66
Left Greave
Retrieve the rear cover of the left leg from issue 43 and the front cover of the left leg, issue 44, picture 2. Note they will both have the letter ā€œLā€ inside the parts.
Place the two parts as shown in picture 3, tucking the chainmail inside. Secure the parts using 6 x LP screws.
Now do the same with the right side, retrieving the parts from issues 45 and 46, picture 4.
Now slide the left greave onto the left leg with the flat end facing upwards. Make sure you align the two holes with the two pegs, picture 5.
Picture 6 shows the complete assembly for this issue.
#5 Posted : 06 July 2026 10:18:39
Issue 67
Left Shin Guard
Retrieve the left shin guard from issue 35. Lay the straps as shown in picture 2 with the longer strap to the top.
Now place the mounting plate over the straps and secure in place using 2 x LP screws, picture 3.
Attach the assembly to the onto the left leg. It attaches to the leg with the magnet and peg that slots into the lower section, picture 4.
Fasten the straps at the back of the leg and tighten then in place, picture 5.
#6 Posted : 06 July 2026 10:21:16
Issue 68
Right Greave
Slide the right greave onto the right leg with the flat end facing upwards. Make sure you align the two holes with the two pegs, picture 2.
Picture 3 shows the complete assembly for this issue.
This page was generated in 0.186 seconds.
