1989 Batmobile Official build STAGES 39 - 44 Options
#1 Posted : 30 June 2026 13:34:10
STAGE 39:
Left side exhaust.
Pic 1: Press-fit exhaust parts 39-1 and 39-2 together.
Pic 2: Fix the assembly to part 39-4 with 1 x B screw.
Pic 3: Fix the other half of the pipe 39-3 in place with 1 x D screw.
Pic 4: Fit the plates 39-7 and 39-8 together as shown and fix the exhaust assembly to it using 1 x D screw.
Pic 5: Retrieve the side panel from stage 38 and fix the exhaust assembly in place as shown using 1 x A screw from the other side.
Pic 6: Fit the pipe 39-5 in place as shown and fix from behind with 1 x D screw.
Pic 7: Press-fit the bracket 39-6 in place where indicated.
Store safely for no
w.
#2 Posted : 02 July 2026 10:45:15
STAGE 40:
Left air intake.
Pic 1: Retrieve the previous assembly and fit the pipes 40-6 in place where shown.
Fix from underneath with 2 x E screws.
Pic 2: Press-fit 40-5 firmly in place as shown.
Pic 3: Clip the two hose components 40-3 and 40-4 together.
Pic 4: Fit the assembly to the previously installed part and fix from underneath with 1 x D screw.
Pic 5: Fit the mesh 40-7 into the air intake 40-1.
It will only fit one way.
Pic 6: Press-fit the cover 40-2 in place.
Pic 7: Fit the assembled intake into the side panel as shown and fix with 2 x B screws.
Store safely for now.
#3 Posted : 03 July 2026 17:00:46
STAGE 41:
Right side skirt.
Pic 1: Lay the skirt 41-1 face down and press-fit the parts 41-3 and 41-4 in place as shown.
Pic 2: On the other side, fix the fitting 41-2 in place where indicated using 1 x D screw.
#4 Posted : 07 July 2026 10:31:12
STAGE 42:
Right side exhaust.
Pic 1: Press-fit exhaust parts 42-1 and 42-2 together.
Pic 2: Fix the assembly to part 42-4 with 1 x B screw.
Pic 3: Fix the other half of the pipe 42-3 in place with 1 x D screw.
Pic 4: Fit the plates 42-7 and 42-8 together as shown and fix the exhaust assembly to it using 1 x D screw.
Pic 5: Retrieve the side panel from stage 41 and fix the exhaust assembly in place as shown using 1 x A screw from the other side.
Pic 6: Fit the pipe 42-5 in place as shown and fix from behind with 1 x D screw.
Pic 7: Press-fit the bracket 42-6 in place where indicated.
#5 Posted : 09 July 2026 13:46:21
STAGE 43:
Right air intake.
Pic 1: Retrieve the previous assembly and fit the pipes 43-6 in place where shown.
Pic 2: Press-fit 43-5 firmly in place as shown.
Pic 3: Clip the two hose components 43-3 and 43-4 together.
Pic 5: Fit the mesh 43-7 into the air intake 43-1.
Pic 6: Press-fit the cover 43-2 in place.
#6 Posted : 14 July 2026 09:47:37
STAGE 44:
Left seat.
Pic 1: Locate the seat frame 44-2 and the mounting plate 44-3.
The parts will fit together where indicated.
Pic 2: Parts assembled.
Pic 3: Fix from underneath with 2 x T screws.
Pic 4: Store safely for now.
This page was generated in 0.235 seconds.
