Ferrari 330 P4 Official Build stages 93 - 98 Options
#1 Posted : 30 June 2026 16:58:17
STAGE 93:
Front right bulkhead.
Pic 1: Press-fit the tank part 93B into the bulkhead 93A as shown.
Pic 2: Turn the bulkhead over and position the pipe 93F where indicated and fix in place with 2 x brackets 93G and 2 x MP screws in each.
Pic 3: Press-fit the drain hose 93C in place.
Pic 4: Turn the main car assembly upside down and make sure all the wires indicated are out of the way.
Pic 5: Fit the bulkhead in place as shown and fix with 2 x AM screws.
Make sure the drain hose is located in the hole where indicated.
Pic 6: With the car the right way up, fit the ends of the pipe shown into the locating holes highlighted.
Pic 7: As before, you can now fit the front wheel if you wish.
Retrieve the brake disc 36C/D and fit it over the stub axle.
Fit the wheel over the disc and then add the central washer 93E.
Fix the wheel with 1 x FM screw.
Pic 8: Fit the centre spinner 37D.
Store the model and unused parts safely for now.
#2 Posted : 01 July 2026 18:20:04
STAGE 94:
Lower left body.
Pic 1: Retrieve the car assembly and fit the on/off switch (wire A) into the location hole on the inside of the lower panel 94A.
Fix with 2 x AGM screws.
Pic 2: Remove the rear panel for now and do not lose the screws.
Pic 3: Panel removed.
Pic 4: Very carefully turn the model over.
Pic 5: Fit the lower panel place making sure the switch wire goes all the way back inside the body so it does not get trapped anywhere.
Fix the panel in place with 5 x TM screws.
Pic 6: Looking down inside the rear of the body, fit 1 x ATM screw in the locating hole as shown.
You will need a fairly long screwdriver for this and be patient.
It is quite fiddly.
Pic 7: re-fit the rear panel.
Pic 8: Clip the battery cover from stage 92 in place.
Pic 9: With the model the right way up, fit 1 x TM screw where shown.
Pic 10: Cut one of the decals 94B from the supplied sheet. There is a spare.
Soak in warm water for about 15 seconds and then slide the decal into place.
Dab it down with a folded tissue or kitchen roll.
Store the model safely.
#3 Posted : 03 July 2026 10:35:31
STAGE 95:
Lower right body.
Pic 1: Retrieve the car assembly and place it upside down.
As before, remove the rear panel and keep the screws.
Pic 2: Position the lower body panel in place.
It is quite fiddly.
After this, re-fit the panel.
Pic 3: Check the lower panel is not trapping any wires anywhere anywhere.
Pic 4: With the model the right way up, fit 1 x TM screw where shown.
Pic 5: If you wish, you can now fit the rear wheel using the brake disc, washer and supplied screw.
Pic 6: Store the model safely.
#4 Posted : 06 July 2026 10:46:59
STAGE 96:
Chassis plate.
Pic 1: Fit the 2 x brackets 96C to the fire extinguisher 96B.
Pic 2: Press-fit the assembly into the chassis plate 96A where indicated.
Pic 3: Retrieve the main car and carefully place it upside down.
Check there are no wires within the yellow circle shown that are outside of the black frame.
If there are, disconnect them, feed the plugs/wires under the frame and reconnect.
Pic 4: Fit the chassis plate and fix with 10 x TM screws.
Pic 5: If you have fitted your wheels, you can now add the 2 x spinners 96D.
#5 Posted : 08 July 2026 12:45:08
STAGE 97:
Front body and decals.
Pic 1: Soak one of the supplied door decals in warm water for around 15 – 20 seconds.
Carefully slide it into place on the door.
Note the very small triangular decal also on the sheet.
It fits where highlighted in yellow.
Dab the decal into place with a folded tissue or kitchen towel.
Pic 2: Apply the lower body decal from stage 95 in the same way.
Pic 3: Retrieve the light assembly from stage 1 to fit into the front body 97A.
Pic 4: From the inside, fit the light unit and fix with 2 x AM screws.
Pic 5: Press-fit the door lights from stage 87 into place.
Make sure the white faces of the lights are all pointing inwards at the numbers.
Pic 6: Apply the front number decal as before making sure the rectangular opening is in line with the recess on the body panel as highlighted in yellow.
#6 Posted : 12 July 2026 16:46:05
STAGE 98A:
Right headlight.
Pic 1: Press-fit the headlight pieces 98D and 98E together.
They will only fit one way.
Pic 2: Fit the lens in place.
There is a small tab on the lens and a recess on the lamp to fit them together.
Pic 3: Fix the assembly into the housing 98B with 2 x AP screws.
Pic 4: Fix the assembly to the light housing 98A as shown using 4 x AP screws.
Pic 5: Locate the indicator parts 98I and 98J.
Pic 6: Press-fit the parts together as shown.
Pic 7: Fit the light into the lamp housing.
#7 Posted : 12 July 2026 16:48:33
STAGE 98B:
Pic 8: Assemble the lamp parts 98G and 98H.
Pic 9: Fit the lens 98F as shown.
Pic 10: Fit the lamp to the housing as shown with the tab at the top right.
Pic 11: Fit the assembly to the front body as shown and fix with 2 x AM screws.
Pic 12: Retrieve the front light LED’s and wired I, F, E and H.
Pic 13: Fit the LED’s E, F and H as shown.
Pic 14: Fit the LED’s F, H and I as shown.
Store the assembly and unused parts safely for now.
This page was generated in 0.298 seconds.
