Lamborghini Revuelto official build Stages 15 - 20 Options
#1 Posted : 01 July 2026 15:47:23
STAGE 15:
Exhaust manifolds.
Pic 1: Retrieve the engine assembly and locate the manifold gaskets 2 x 15A.
They will fit where indicated.
Pic 2: Fix the gaskets in place using 12 x E screws.
Pic 3: Assemble the manifold parts 15B and 15C, 15D and 15E.
Fix them with 1 x F screw in each.
Pic 4: Store everything safely for now.
#2 Posted : 02 July 2026 13:37:52
STAGE 16:
Catalytic converter.
Pic 1: Fit the catalytic converter parts 16A and 16B together.
Fix them with 3 x F screws.
Pic 2: Locate the clamp parts 16C and 16E, and the muffler fitting 16D.
Pic 3: The clamp 16E has a small ‘key’ on the inside which will locate on the converter flange.
Fit the other clamp part, trapping the muffler connector in place and fix with 2 x F screws.
Pic 4: Retrieve the manifold assemblies from the previous stage and fit one into the catalytic converter as shown.
Make sure the orientation of the parts is as shown.
Pic 5: Fit the clamp parts 16F and 16G in place and fix with 2 x F screws.
NOTE – If you find the clamps don’t fit easily you can file down the flat faces on the ends of the catalytic converter a little.
Pic 6: Fit the other manifold in the same way, paying attention to the orientation of the parts.
Pic 7: Retrieve the engine assembly and fit the manifolds in place on the left cylinder head as shown.
Fix from the top using 4 x E screws.
Store safely for now.
#3 Posted : 05 July 2026 13:37:59
STAGE 17:
Exhaust manifolds.
Pic 1: Retrieve the engine assembly.
The manifold gaskets will fit where indicated.
Pic 2: Fix the gaskets in place with 12 x E screws.
Pic 3: Assemble the manifold parts as shown and fix with 1 x F screw in each.
Pic 4: Store safely for now.
#4 Posted : 07 July 2026 10:34:49
STAGE 18:
Pic 1: Fit the catalytic converter parts 18A and 18B together.
Pic 2: Locate the clamp parts 18C and 18E, and the muffler fitting 18D.The clamp 18E has a small ‘key’ on the inside which will locate on the converter flange.
Pic 3: Retrieve the manifold assemblies from the previous stage and fit one into the catalytic converter as shown.
Fit the clamp parts 18F and 18G in place and fix with 2 x F screws.
Pic 4: Fit the other manifold in the same way, paying attention to the orientation of the parts.
Pic 5: Retrieve the engine assembly and fit the manifolds in place on the right cylinder head as shown.
#5 Posted : 10 July 2026 18:43:22
STAGE 19:
Left camshaft cover.
Pic 1: Press-fit the 6 x spark plugs 19B into the top of the cover 19A.
They will only fit one way.
Pic 2: Fix from the other side with 6 x F screws.
Pic 3: Fit the cover to the engine as shown and fix with 5 x E screws.
Pic 4: Fit the end plate 19C to the end of the engine and fix with 1 x F screw and 2 x E screws.
#6 Posted : 14 July 2026 12:06:12
STAGE 20:
Right camshaft cover.
Pic 1: Press-fit the 6 x spark plugs 20B into the top of the cover 20A.
Pic 4: Fit the end plate 20C to the end of the engine and fix with 1 x F screw and 2 x E screws.
This page was generated in 0.751 seconds.
