Red Bull RB19 Official build. Stages 75 - 80 Options
#1 Posted : 17 July 2026 15:46:49
STAGE 75:
Front right wheel.
Pic 1: Fit the rim parts 75B and 75D together as shown and fix with 2 x A screws.
Pic 2: Turn the assembly over and press-fit the trim ring 75C in place.
Pic 3: Press-fit the assembly into the front of the wheel rim 75A.
Pic 4: Retrieve the rear suspension assembly and the 2 x pushrods 74I saved from the previous stage.
Press-fit the parts in place as indicated.
Pic 5: Store safely for now.
#2 Posted : 21 July 2026 11:17:34
STAGE 76:
Floor panel.
Pic 1: Place the floor panel 76A upside down.
The reinforcement bar 76B will fit where indicated.
Pic 2: Fix the part with 2 x G screws.
Pic 3: Repeat on the other side with part 76C.
Pic 4: Fix with 2 x G screws.
#3 Posted : 23 July 2026 12:30:56
STAGE 77:
Venturi baffles.
Pic 1: Retrieve the floor panel and place it upside down.
Fit the venture baffle 77A as shown and fix from underneath with 1 x A screw.
Pic 2: Repeat on the other side with baffle 77B.
Pic 3: Store safely for now.
#4 Posted : 25 July 2026 13:35:05
STAGE 78:
Front right wheel – Rain tyre.
Pic 1: Retrieve the wheel from stage 75.
The tyre 78A will fit onto it.
Pic 2: You may find it easier to fit the tyre if you soak it in hot water for a few minutes.
Dry the tyre inside and out and press it onto the wheel rim.
Take care with hot water.
The use of hot water is at the builder’s discretion.
Pic 3: Store the wheel safely.
#5 Posted : 29 July 2026 13:30:35
STAGE 79:
Venturi baffles 2.
Fit the baffle 79A as shown and fix with 1 x A screw from underneath.
Pic 2: Repeat with baffle 79B on the other side.
#6 Posted : 05 August 2026 12:08:33
STAGE 80:
Venturi baffles 3.
Fit the baffle 80A as shown and fix with 1 x A screw from underneath.
Pic 2: Repeat with baffle 80B on the other side.
This page was generated in 0.214 seconds.
