 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
STAGE 93:
Left front wing.
Pic 1: Retrieve the upper body and fit 2 x CM screws where shown, then remove them. It will make fitting them with the door in place easier.
Pic 2: Fit the left door and then fix with the 2 x CM screws.
Pic 3: On the inside, open the door and fix the retaining strap with 1 x ALM screw.
Pic 4: Fix the spacer 93B to the wing 93A as shown using 3 x AM screws.
Pic 5: Fit the wing in place on the body and fix from the inside with 1 x AM screw and 2 x BM screws.
Pic 6: Retrieve the front grille section and fix the light shroud 93C over the lamp 1D using 1 x AP screw.
Pic 7: Press-fit the light cover 93D in place as shown making sure the tab on one side faces up. NOTE: The printed instructions incorrectly refer to these parts as the rear tail light.
Pic 8: Store everything safely for now.roymattblack attached the following image(s):
STAGE 94:
Bonnet.
Pic 1: Retrieve the body and fit the wing support 94A as shown and fix with 3 x AM screws.
Pic 2: Fix the bonnet support 94C using 1 x SM screw. Make sure the angled end faces inwards.
Pic 3: Fix the hinge support 94E to the bonnet 1A using 2 x TM screws.
Pic 4: Fix the hinge 94F in place using 1 x QM screw.
Pic 5: Repeat on the other side using the parts 94G and 94H.
Pic 6: Fit the angled bracket 94D into the recess on the bonnet as shown and fix with 1 x SM screw.
Store the assembly and unused part safely for now.roymattblack attached the following image(s):
STAGE 95:
Right front wing.
Pic 2: Fit the right door and then fix with the 2 x CM screws.
Pic 4: Fix the spacer 95B to the wing 95A as shown using 3 x AM screws.
Pic 6: Fix the wing support 94B in place using 3 x M screws.
Pic 7: Retrieve the front grille section and fix the light shroud 95C over the lamp 1D using 1 x AP screw.
Pic 8: Press-fit the light cover 95D in place as shown making sure the tab on one side faces up.
STAGE 96A:
Front lights.
Pic 1: Fit the turn signal parts 96E, 96F, 96G and 96H together as shown.
Pic 2: Retrieve the front bumper 3A and fit the signal parts 96G/H in place as shown. Fix with 1 x AP screw and 1 x AM screw.
Pic 3: Repeat on the other side with signal parts 96E and 96F.
Pic 4: Fix the bumper support panels 96I and 96J in place where indicated using 2 x AM screws in each.
Pic 5: Retrieve the main assembly and fix the long LED’s 50D as shown using short pieces of tape 71D.
Pic 6: Retrieve the front bumper assembly and place it in front of the chassis.
STAGE 96B: Pic 7: Fit the bumper in place keeping all LED wires out of the way. You may find it helpful to use strips of low tack masking tape to keep the part in place. This is at the builder's discretion. Pic 8: Turn the model over and fix the bumper inside the wheel arch as shown using 2 x AM screws. Pic 9: Repeat on the other side. Pic 10: Remove the masking tape if you used any. Pic 11: Plug the Black/yellow LED into the turn signal holder. Plug the red/blue LED into the back of the headlight. Pic 12: Repeat on the other side. Pic 13: Plug the long Black/red LED’s into the backs of the spotlights. roymattblack attached the following image(s):
STAGE 96C:
Pic 14: You can now test the front lights to make sure all is working. Use the printed instructions as a guide.
Pic 15: Fit the front cover 96A and fix from underneath with 2 x AP screws.
Pic 16: Repeat on the other side with part 96C.
Pic 17: Feed the hose from the top of the radiator through the hole in the cover panel 96C as shown.
Pic 18: The sticky pads 96K and 96L will attach to the backs of the panels 96B and 96D.
Pic 19: Peel the backing from the pads and stick the panels in place as shown.
Store safely for now.
STAGE 97A:
Body, side skirt and mud flap.
Pic 1: Fit the bonnet assembly to the main body as shown and fix with 2 x AM screws.
Pic 2: Bonnet fitted.
Pic 3: Lift the bonnet and keep it open using the bonnet stay.
Pic 4: On the main chassis, make sure the hoses indicated are tucked out of the way.
Pic 5: Open the doors and lower the body onto the chassis.
Pic 6: Make sure the body is all the way down and close the doors and bonnet.
STAGE 97B:
Pic 7: For the time being, you can tape the doors and bonnet closed using low tack masking tape. This is at the builder’s discretion.
Pic 8: Connect the air duct as shown.
Pic 9: Fix the upper body at the rear with 2 x TM screws.
Pic 10: Carefully turn the model over and fix the body with 6 x BM screws where indicated.
Pic 11: Fix the front wings with 4 x CM screws where indicated.
Pic 12: Fit the side skirt 97A as shown and fix with 4 x AM screws.
Pic 13: Press-fit the left mud flap 97B in place, locating the tabs in the slots on the black support.
STAGE 98:
Starter motor, side skirt and mud flap.
Pic 1: Starter motor parts 89C and 98D will push-fit together.
Pic 2: Parts assembled.
Pic 3: Fit the sticky-pad 98E to the end of the motor.
Pic 4: The circled area shows where the starter motor is fitted after removing the backing from the sticky pad. Access to this area is extremely difficult at this stage and as the fitted component will be completely invisible once the floor panel is added it is at the builder’s discretion whether to attempt fitting the part.
Pic 5: Fit the side skirt 98A as shown and fix with 4 x AM screws.
Pic 6: Press-fit the mud flap 98B in place, locating the tans on the lower face in the slots on the black support plate.
Store the model safely.roymattblack attached the following image(s):
