Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,312 Points: 22,243 Location: Northamptonshire, England
Issue 66
The Upper Left Spider Leg Picture 1 show the parts for this issue Attach the claw joint to the claw joint detail by using a type E screw, pictures 2, 3 and 4.
Push fit the claw upper profile as shown in picture 5. Identify the two claw sides, picture 6 and place the right inner body, the bottom one in picture 6, onto the part you’ve just assembled, picture 7. Place a type E screw to hold it in place, picture 8.
Fit the left inner claw on the other side and secure it in place using a type E screw, picture 9.
Insert the assembly into the claw tip as illustrated in pictures 10 and 11.
Fit the right blue claw plate into the claw tip, picture 12. Turn the assembly over and apply two type E screws to hold it in place, picture 13. Push fit the other side of the blue claw plate, picture 14.
Picture 15 shows the assembly complete for this issue.
Issue 67
The Upper Left Spider Leg Picture 1 show the parts for this issue Retrieve the assembly from issue 65 and fit the smaller blue plate as shown in picture 2. Holding the plate in place, turn the assembly over and fit the larger blue plate, securing both in place using 3 x type E screws, picture 3. Once you have tightened all the screws, fit the three cover plates over the screw holes, picture 4.
Placing the washers on the joint end of the second segment, place the left and right structures of the third segment and position them over the joint and washers, pictures 5 and 6. Once in place secure the parts using the screw and M3 nut, pictures 7 and 8.
Retrieve the claw assembly from the last issue and secure it to the end of the third segment in the same way as before using the two washers, screw and the M3 nut, pictures 9 and 10.
Issue 68
The Upper Left Spider Leg Picture 1 show the parts for this issue Retrieve the assembly from issue 67. On the outside of the third segment, fit the third joint cover on the outside, picture 2. Turn the assembly over and secure it in place using 2 x G screws, picture 3. Place the two blue circular joint covers on the side as shown in picture 4, push fitting the two parts in place.
Fit the gold detail on the upper blue plate securing it in place using a type E screw, pictures 5 and 6.
Fit the assembly on the upper side of the third segment, picture 7. Turn the assembly over and place the smaller blue detail on the opposite side, picture 8. With both parts in place, turn the assembly over again and place 2 x E screws as shown in picture 9. Place the blue cover plate over the screws, picture 10, then fit the gold side cover in place as shown in picture 11.
Finally, place the two blue circular side parts in place on the claw joint, picture 12.
Picture 13 shows the assembly complete for this issue.
