Issue 75
Trunk Lid Inner Panel Picture 1 show the parts for this issue. Fit the inner trunk panel into the trunk lid, securing it in place using 5 x H screws, picture 2.
Now attach the trunk lock anchor plate to the inner panel and secure in place using 2 x N screws, picture 3.
Picture 4 shows the assembly complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 76
Front Bumper and Headlights Picture 1 show the parts for this issue. Start the assembly by fitting the front bumper to the grill assembly from earlier in the build. Attach it using 4 x type C screws, picture 2.
Tale the cable marked D2 and place each bulb into the main headlights as shown in picture 3. Take the second cable, marked D1 and connect the LED bulbs into the high beam lights, picture 4.
Fit the two pins of the turn signal lens and place them into the holes in the turn signal housing, picture 5.
Picture 6 shows the assembly complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 77
Right Front Wheel Picture 1 show the parts for this issue. Insert the pins on the inside of the front wheel hub, picture 2. Place the assembly onto the wheel rim and secure it in place using 3 x C screws as shown in pictures 3 and 4.
Issue 78
Right Front Wheel Picture 1 show the parts for this issue. Before fitting the tyre, note the outside wall has some white markings that do not appear on the inside. Press the assembly from the previous issue into the tyre, picture 2. Tip: you may want to put the tyre into some hot water to soften it making it more pliable to fit.
To complete the wheel, press the three pins on the wheel centre rim into the holes in the wheel centre, picture 3.
Issue 79
Left Hand Door Picture 1 show the parts for this issue. Place the door hinge over the recess inside the front of the door, picture 2 and fit the hinge mounting plate onto the hinge and secure in place using 2 x K type screws, picture 3.
Issue 80
Left Hand Door Picture 1 show the parts for this issue. Fit the window guide in the inside of the right-hand door and secure it in place using 4 x F screws, picture 2.
Insert the flange on the rear-view mirror through the hole in the top of the door and secure it in place using an F type screw, picture 3. Take the backing paper off the mirror and stick it to the inside of the mirror housing, pictures 4 and 5.
Push fit the door lock in place, picture 6. Fit the door handle to the door and secure it in place on the opposite side using a D type screw, pictures 7 and 8.
Picture 9 shows the assembly complete for this issue.
