Premium Base Pack 6 Screws Options
Marc007
#1 Posted : 31 July 2026 17:40:52
Rank: Newbie
When I received the premium base build issue 6, the instructions show the build requires C screws. In my pack I received a pack of B screws so I contacted Fanhome and asked for a replacement pack 6 with the correct pack of C screws. The replacement arrived, however; again, it contained B screws. I have been informed through social media that the build instruction magazine was incorrect. Is this true, can admin confirm this please?
Marc007
#2 Posted : 01 August 2026 10:14:39
Rank: Newbie
Received an email this morning from Fanhome.
Quote:
Dear Customer,
We have identified a printing error in the assembly instructions for Stage 6 of the Premium Base included with your Darth Vader build, apologises for any confusion this may have caused.
After reviewing the assembly steps, we can confirm the following:
The B screws are required to complete the assembly.
The C screws shown in the printed instructions are not required for these steps.
The printed guide incorrectly indicates that C screws should be used.
The correct assembly only requires the B screws, so if you believe you are missing C screws, your Stage 6 pack is complete and no replacement parts are required.
The correct screw usage for Stage 6 is as follows:
Step 3 (Part 6.1): Use 8 × B screws (2.6 × 6 mm).
Step 4 (Part 6.2): Use 8 × B screws (2.6 × 6 mm) only.
Step 5 (Part 6.3): Use 6 × B screws (2.6 × 6 mm) to secure the three joining bridges.
We apologise for any inconvenience caused by this printing error and appreciate your understanding.
Kind regards,
Customer Services Fanhome
