Premium Base Pack 6 Screws Options
Marc007
#1 Posted : 31 July 2026 17:40:52
Rank: Newbie
When I received the premium base build issue 6, the instructions show the build requires C screws. In my pack I received a pack of B screws so I contacted Fanhome and asked for a replacement pack 6 with the correct pack of C screws. The replacement arrived, however; again, it contained B screws. I have been informed through social media that the build instruction magazine was incorrect. Is this true, can admin confirm this please?
Marc007
#2 Posted : 01 August 2026 10:14:39
Rank: Newbie
Received an email this morning from Fanhome.
Quote:
Dear Customer,
We have identified a printing error in the assembly instructions for Stage 6 of the Premium Base included with your Darth Vader build, apologises for any confusion this may have caused.
After reviewing the assembly steps, we can confirm the following:
The B screws are required to complete the assembly.
The C screws shown in the printed instructions are not required for these steps.
The printed guide incorrectly indicates that C screws should be used.
The correct assembly only requires the B screws, so if you believe you are missing C screws, your Stage 6 pack is complete and no replacement parts are required.
The correct screw usage for Stage 6 is as follows:
Step 3 (Part 6.1): Use 8 × B screws (2.6 × 6 mm).
Step 4 (Part 6.2): Use 8 × B screws (2.6 × 6 mm) only.
Step 5 (Part 6.3): Use 6 × B screws (2.6 × 6 mm) to secure the three joining bridges.
We apologise for any inconvenience caused by this printing error and appreciate your understanding.
Kind regards,
Customer Services Fanhome
This page was generated in 0.192 seconds.
