Ferrari 330 P4 Official Build stages 99 - 104 Options
#1 Posted : 04 August 2026 11:12:28
STAGE 99A:
Front body and air intakes
Pic 1: Retrieve the front body and place it upside down.
Tape the light cables down as shown.
Pic 2: Fit the air intake frame 99A and fix with 3 x AM screws.
Pic 3: Fit the left brake hose manifold 99B as shown and fix with 2 x AM screws.
Pic 4: Fit the right brake hose manifold 99C as shown and fix with 2 x AM screws.
Pic 5: Press-fit the inner brackets 99E and 99F in place where indicated.
Pic 6: Fit the air intake cover 99D in place.
#2 Posted : 04 August 2026 11:15:06
STAGE 99B:
Pic 7: Gather the light cables and tie them using the cable tie 99G.
Cut off the excess afterwards.
Pic 8: Retrieve the main body.
Pic 9: Position the front body as shown and connect all the wires and plugs.
Take care to connect the matching letters.
Pic 10: Turn the body panel over and fit it in place.
Fix using 6 x TM screws and 2 x AKP screws.
Pic 11: Fix the lower body with 1 x AUM screw.
Repeat on the other side.
Pic 12: Fit the light cover 98K as shown and fix with 2 x MM screws.
Pic 13: Fit the light cover 98L as shown and fix with 2 x MM screws.
#3 Posted : 07 August 2026 14:03:16
STAGE 100:
Lower front body.
Pic 1: Soak one of the supplied decals 100F in warm water for about 10 seconds and then slide the decal into place as shown.
Dab with a folded tissue or paper towel and allow to dry.
Pic 2: Locate the extension 100D. It fits on the right side of the panel 100A.
It can be identified by the pin on the lower side.
Fix in place with 2 x AM screws.
Pic 3: Locate the extension 100B. It fits on the left side of the panel 100A.
Pic 4: Locate the brackets 100C and 100E.
They can be identified by the letters ‘L’ and ‘R’ on each part.
Pic 5: With the panel 100A facing up, fit the bracket 100C as shown.
It has been outlined to make it show more clearly.
Pic 6: With the panel 100A facing up, fit the bracket 100E as shown.
Pic 7: Turn the car assembly upside down and fit the front panel as shown.
It will slide under the black brackets and two pins inside will locate in holes in the panel.
Fix with 3 x AM screws.
Pic 8: Store the model safely.
#4 Posted : 10 August 2026 14:24:52
STAGE 101:
Rear hood.
Pic 1: Press-fit a locking handle 101B into the lower front of the hood 101A.
Pic 2: Repeat on the other side.
Pic 3: Retrieve the main assembly and remove the screws and hinge section indicated.
Pic 4: Make sure you store the screws safely, or for now you could re-fit them on the car.
Pic 5: Fit the hinge part you just removed, 71B, to the rear hood hinge part 101C as shown and fix from each end with 1 x AUM screw.
Pic 6: Turn the hood over and fit the assembly as shown, fixing it with 3 x UM screws.
Pic 7: Store safely for now.
#5 Posted : 22 August 2026 11:38:54
STAGE 102:
Rear hood and air intake.
Pic 1: Fix the air intake 102B into the panel 102A as shown with 6 x AP screws.
Pic 2: Retrieve the rear hood and slide the panel in as shown.
Pic 3: From the inside fix the parts using 3 x AP and 2 x AM screws.
Pic 4: Store safely for now.
#6 Posted : 23 August 2026 14:06:12
STAGE 103:
Rear hood lower panel.
Pic 1: Fix the brackets 103B to the lower panel 103A as shown using 2 x AHM screws.
Pic 3: Locate the right brackets (marked R) 103D and 103F.
Fix them as shown with 2 x AM screws.
Pic 4: Locate the left brackets (marked L) 103C and 103E.
Pic 5: Retrieve the rear body and fit the right bracket as shown, fixing it with 2 x AM screws.
Pic 6: Repeat on the other side with the left bracket.
Pic 7: Store the parts safely for now.
#7 Posted : 26 August 2026 15:27:38
STAGE 104:
Tail lights & grilles.
Pic 1: Assemble 2 x sets of tail lights using parts 104A and 104B.
Pic 2: Assemble 2 x sets of smaller tail lights using parts 104E, 104C (marked on the back ‘L’) and 104D (marked on the back ‘R’).
Pic 3: Fit one of the larger lights at the top left of the rear panel with the red section at the bottom.
Fit the smaller ‘L’ light underneath.
Pic 4: From the other side, fix the lights with 4 x AM screws.
Pic 5: Repeat on the right side of the rear panel.
Pic 6: Press-fit the two grilles 104F and 104G onto the small locating pins at the upper edge of the tail panel.
The two grilles are actually identical.
NOTE – The grilles are a very loose fit so you may be advised to fix them with tiny dots of adhesive.
Pic 7: Store the assembly and unused parts and screws safely for now.
This page was generated in 0.217 seconds.
