1989 Batmobile Official build STAGES 45 - 50 Options
#1 Posted : 06 August 2026 11:33:39
STAGE 45:
Headrests.
Pic 1: Locate the headrest parts 45-1, 45-2 and 45-3.
The parts will press-fit together in the order shown.
Pic 2: Parts assembled.
Pic 3: Make two sets.
Pic 4: Retrieve the seat from the previous stage and fix a headrest in place as shown using 2 x S screws.
Pic 5: Press-fit the seat back from the previous stage in place.
Pic 6: Store all parts including the spare screws.
They will be needed to fix the other headrest.
#2 Posted : 08 August 2026 10:59:19
STAGE 46:
Seat 2.
Pic 1: Fit the seat plate 46-3 onto the base 46-2 and fix from below with 2 x T screws.
Pic 2: Retrieve the unused headrest 45A and screws from the previous stage.
Fit the headrest to the seat 46-1 as shown and fix with the 2 x S screws.
Pic 3: Press the seat back 46-2 in place on the back of the seat 46-1.
Pic 4: Store safely for now.
#3 Posted : 10 August 2026 14:41:52
STAGE 47:
Gear shifts and control panel.
Pic 1: Locate the gear shift parts 47-1, 47-2, 47-3 and 47-5.
The levers will fit into the slots on 47-5 in the order shown with 47-1 and 47-3 angled outwards.
Pic 2: Fit the parts together as shown, locking them in place with the pin 47-4.
Pic 3: Press-fit the assembly onto the base 47-6.
Pic 4: Press the lights 3 x 47-9 into the control plate 47-7 as shown.
Pic 5: Fit the LED panel 47-8 to the rear of the panel 47-7.
Pic 6: Store the parts safely for now.
#4 Posted : 22 August 2026 15:29:03
STAGE 48:
Interior floor.
Pic 1: Retrieve the two seats and fit them to the floor 48-1 as shown.
Pic 2: Fix from underneath with 3 x B screws in each.
Pic 3: Retrieve the assembly 47C and feed the wire through the hole in the central column.
Press the panel in places as indicated.
Pic 4: From underneath, fit the gear levers 47B through the hole in the central tunnel.
They will only fit one way.
Pic 5: Fix from underneath with 2 x D screws.
#5 Posted : 25 August 2026 11:28:38
STAGE 49:
Pedals.
Pic 1: Fit the bracket parts 49-4 into the holder 49-3 as shown.
Make two sets.
Pic 2: Fit the assemblies to either side of the pedal 49-1.
Pic 3: Press-fit the assembly in place inside the interior where indicated.
Pic 4: Fit the brake pedal 49-2 into the interior.
It will hook over the front wall where indicated.
#6 Posted : 27 August 2026 12:14:37
STAGE 50:
Rear LED panel and steering wheel.
Pic 1: Fix the LED panel 50-3 into the base 50-2 using 1 x D screw.
Pic 2: Retrieve the steering wheel from stage 4 and disassemble it carefully.
Pic 3: Fit the rear wheel boss 4-32 to the column 50-4 and then fit the steering wheel.
Secure the parts with 1 x O screw.
Pic 4: Press the central cover back in place
Pic 5: Retrieve the dashboard assembly and fit the steering column in place.
Add the securing bracket 50-5 and fix with 2 x D screws.
Pic 6: Fit the dashboard assembly into the interior as shown and fix from underneath with 2 x P screws.
Store everything including the unused part safely for now
This page was generated in 0.289 seconds.
