Chevrolet Nascar Official Build stages 93 - 98 Options
#1 Posted : 06 August 2026 12:56:03
STAGE 93:
Roll cage rear cross member and dashboard.
Pic 1: Retrieve the dashboard parts from the previous stage and feed the LED wire from the instrument panel through hole in the dashboard as shown.
Pic 2: Fit the panel to the dashboard and fix with 3 x EP screws from behind.
Pic 3: Retrieve the dashboard brace 89A and fix it under the dashboard with 3 x EP screws.
Pic 4: Retrieve the steering wheel assembly and fit it into the column.
Pic 5: Fit the cross-brace 93A into the interior behind the driver’s seat as shown, noting where it connects to the centre brace.
Check the orientation of the parts.
Store safely for now.
#2 Posted : 09 August 2026 11:22:15
STAGE 94:
Roll cage lower rear brace.
Pic 1: Fit the brace 94A in the position indicated.
Pic 2: Fix from underneath with 2 x AP screws.
Pic 3: Fix through the cross-brace with 2 x AP screws.
Pic 4: Fit the bracket 94B to the central brace as shown and fix using 1 x MP screw.
#3 Posted : 10 August 2026 14:30:07
STAGE 95:
Attaching the dashboard.
Pic 1: Fit the dashboard brace 95A to the top of the dashboard as shown and fix with 1 x AP screw from underneath.
Pic 2: Turn the dashboard over and fit the cable tie around the main brace as shown but do not pull it tight yet.
Pic 3: Retrieve the interior and lay the dashboard upside down in front.
Feed the long silver fire extinguisher line along the side of the interior and pass it through the cable tie.
Pull the tie tight and cut off the excess.
Pic 4: Feed the twisted wires into the hole in the dashboard brace.
Pic 5: Fit the dashboard in place on the interior.
Make sure the steering column goes through the hole in the firewall.
Pic 6: From underneath, fix the dashboard to the angled bracket using 1 x AM screw.
Pic 7: Repeat on the other side.
Store safely and keep the self-adhesive felt strips until later.
#4 Posted : 22 August 2026 12:15:10
STAGE 96:
Roof roll cage.
Pic 1: Retrieve the 3 x self-adhesive strips from the previous stage and fix them to the roll cage 96A in the positions shown.
Make sure you have the roll cage placed as indicated.
Pic 2: Cut the wire 96B into 6 x 40mm lengths.
Pic 3: Bind the wires around the ends of the black strips as shown.
Pic 4: Carefully trim off the excess wire and fold the twists down.
#5 Posted : 24 August 2026 13:34:59
STAGE 97:
Right side roll cage.
Pic 1: Wrap the self-adhesive strip 97C around the upper bar on the frame 97A as shown.
Pic 2: As before, wrap 2 x 40mm pieces of wire 97D around the ends of the strip.
Twist the wires and cut off the excess.
Pic 3: Fix the support bar 97B to the main frame using 1 x AP screw.
Pic 4: Retrieve the roof cage from the previous stage and fix it to the side frame as shown using 2 x AP screws.
Pic 5: Fit the assembly to the car interior, locating all the fixings carefully.
This needs a bit of ‘wiggling’ so be patient.
Fix the front of the frame where indicated using 1 x CM screw.
Pic 6: From underneath, fix the frames in place using 5 x EP screws.
Pic 7: Fix the inner cross members using 3 x AP screws.
Pic 8: Fix the front screen bar with 1 x AP screw.
#6 Posted : 27 August 2026 13:30:31
STAGE 98:
Left side roll cage.
Pic 1: Wrap the self-adhesive strip 98C around the upper bar on the frame 98A as shown.
As before, wrap 2 x 40mm pieces of wire 98D around the ends of the strip.
Pic 2: Fix the curtain bracket 98B in place as shown using 1 x AP screw.
Pic 3: Wiggle the frame into place on the left side of the interior assembly.
Fix the front bracket using 1 x CM screw.
Pic 4: Fit another 4 x AP screws where shown.
Pic 5: From underneath, fix the frame legs using 2 x EP screws.
Pic 6: Store safely for now.
This page was generated in 0.554 seconds.
