Iron Spiderman Official Build Issues 69 - 71 Options
#1 Posted : 12 August 2026 10:26:10
Issue 69
The Upper Right Spider Leg
Picture 1 show the parts for this issue
Join the two parts together using a ā€œPā€ screw with a washer as shown in pictures 2, 3 and 4. Use the M4 Allen key.
Picture 5 shows the assembly complete for this issue.
#2 Posted : 13 August 2026 09:43:09
Issue 70
On the inside of the first joint cover, fit one of the inner supports and secure it in place using 2 x type F screws, picture 2.
Retrieve the assembly from the previous issue and position the 4 holes of the first segment structure and secure it in place using 4 x type J screws with a washer on each one, pictures 3 and 4. Now fit the cover and secure in place with a type J screw and washer, picture 5.
On the left side of the first joint, fit one of the side covers, so its hole fits over the hollow post on the joint as shown in picture 6. Fit one of the joint caps on the post and fix the parts using a type V screw, picture 7. Do the same on the other side of the joint, picture 8.
Take the assembly and join the end to the second joint, using 2 x type J screws and washers as before, pictures 9 and 10.
On the inside of the second joint cover, fit one of the inner supports and secure it in place using 2 x type F screws, picture 11.
Fix the assembly to the second joint as shown in picture 12, using a type J screw with washer.
#3 Posted : 14 August 2026 10:21:15
Issue 71
Take the long assembly from the previous issue and position the inner blue part as shown in picture 2. Place the other blue part the other side in the same way, then place the central blue part over the two side pieces and secure it in place using 6 x type E screws, picture 3. Once secure, place the three-cover plate over the screws. Note: The cover plates are numbered 1 -3, so make sure they are placed in order, picture 4 and 5.
At the open end of the second joint, fit the second segment structure. Use 3 x type J screws and 3 x washers to secure the two parts together, picture 6. Now fit the second joint cover securing it using 2 x type F screws, picture 7. Turn the assembly over and place a type J screw plus a washer on place as shown in picture 8.
On the two sides of the second joint, push fit the two screw caps, pictures 9 and 10.
In the recess on the underside of the third joint, fit the blue detail, picture 11.
Position the third joint onto the end of the second segment and secure the two parts together using 3 x type J screws and 3 x washers, picture 12.
Finally, fit the third joint cover as shown in picture 13, using 2 x type J screws and 2 x washers.
Picture 14 shows the assembly complete for this issue.
This page was generated in 0.083 seconds.
