John Wick Ford Mustang Official Build Pack 16 Options
#1 Posted : 24 August 2026 09:25:21
Issue 81
Right Hand Door
Picture 1 show the parts for this issue.
Start by placing the right-hand slide into the inside of the panel and secure it in place using 2 x D screws, pictures 2 and 3.
Fit the door chrome trim as shown in picture 4, followed by the wood effect panel insert by pushing the two pins in place, picture 5.
#2 Posted : 25 August 2026 10:41:24
Issue 82
Left Hand Door
Fit the door window handle into the door as shown in pictures 2 and 3, the turn the assembly over and fit the door window gear, securing them both using a “I” type screw, picture 4.
Place the door light switch and cable on the door switch bracket securing it in place using an M screw as illustrated in picture 5.
Fit the door light lens into the slot in the door panel, picture 6. Fit the door light housing, picture 7, then attach it to the door panel over the door light lens, picture 8. Place the door light housing over the LED and lens and secure it in place using 2 x M screws, picture 9. Picture 10 shows the inner panel complete.
Turn the assembly over and press the rear view mirror adjustment knob into the housing, picture 11.
Picture 12 shows the assembly complete for this issue.
#3 Posted : 26 August 2026 09:08:00
Issue 83
Left Hand Door
Attach the door window intermediate gear in place as shown in picture 2 and secure it using a type “I” screw. Now fit the window lifter arm in place and secure it using another type “I” screw, picture 3.
Attach the window over the post of the window arm lifter and secure it in place using a type “I” screw, picture 4.
Take the door assembly and attach it to the door panel using 3 x F screws as shown in pictures 5 and 6. Turn the assembly to the side and attach a type A screw, picture 7.
Fit the pins on the lower door panel into the door panel, then finally attach the chrome trim as shown in picture 8.
#4 Posted : 27 August 2026 09:42:48
Issue 84
Hood/Bonnet Hinges
Start the assembly by placing the hood/bonnet front trim in place using 4 x O screws, picture 2.
Next, place the right hood/bonnet hinge on the right underside of the hood/bonnet and secure it in place using 2 x E screws as shown in picture 3. Do the same with the left-hand hinge.
Picture 4 shows the assembly complete for this issue.
#5 Posted : 31 August 2026 16:01:48
Issue 85
Hood/Bonnet Lock
Start the assembly by aligning the two hood parts together as shown in picture 2 and secure the two parts together using 2 x D screws. Fit the lower hood lock and secure it to the assembly using a I type screw, pictures 3 and 4.
Picture 5 shows the assembly complete for this issue.
#6 Posted : 31 August 2026 16:03:35
Issue 86
Vacuum Tank and Air Conditioning Filter.
Start by fitting the two rubber bumpers to the mounting brackets, picture 2.
Press fit the vacuum tank top to the vacuum tank, picture 3. Attach the vacuum tank ducts into the top of the tank, picture 4.
Press the air conditioning top into the filter unit, picture 5. Fit the two ends of the level pipe into the two holes on the side of the filter, picture 6. Note: I used a spot of glue to hold it in place.
Finally, insert the filter pipe into the hole in the top of the air conditioning filter, picture 7.
This page was generated in 1.107 seconds.
