Red Bull RB19 Official build. Stages 81 - 86 Options
#1 Posted : 28 August 2026 11:05:45
STAGE 81:
Rear left wheel.
Pic 1: Locate the wheel cover parts 81B and 81C.
They will fit together as indicated.
Pic 2: Fix the parts together with 2 x A screws.
Pic 3: Press the assembly into the front of the wheel 81A as shown.
Store safely for now.
#2 Posted : 30 August 2026 14:05:40
STAGE 82:
Chassis closing panel.
Pic 1: Fit the closing panel 82A to the chassis as shown.
Pic 2: Fix with 2 x A screws where indicated.
#3 Posted : 31 August 2026 12:44:09
STAGE 83:
Rear body panels.
Pic 1: Fit the right panel 83B as shown and fix with 2 x A screws.
Pic 2: Fit the left panel 83B as shown and fix with 2 x A screws.
#4 Posted : 02 September 2026 13:24:43
STAGE 84:
Rear left wheel – Rain tyre.
Pic 1: Retrieve the wheel from stage 81.
The tyre 84A will fit onto it.
Pic 2: You may find it easier to fit the tyre if you soak it in hot water for a few minutes.
Dry the tyre inside and out and press it onto the wheel rim.
Take care with hot water.
The use of hot water is at the builder’s discretion.
Store the wheel safely.
#5 Posted : 03 September 2026 10:30:05
STAGE 85:
Circuit board.
Pic 1: Fix the circuit board 85D to the chassis with 3 x T screws as shown.
Pic 2: Fix the switch 85C to the chassis with 2 x T screws.
#6 Posted : 04 September 2026 10:36:11
STAGE 86:
Upper radiator 1.
Pic 1: Fix the manifold 86B to the radiator 86A with 2 x T screws.
Pic 2: Press-fit the bracket 86C in place as shown.
This page was generated in 0.197 seconds.
