Darth Vader Official Build Pack 13 Options
#1 Posted : 31 August 2026 17:02:48
Issue 63
Right Leg
Retrieve the right knee assembly from issue 63. Insert the friction disc in the base and secure in place using 4 x V screws, picture 2.
Slot the right mobile knee bar onto the friction disc and secure in place using 4 x W screws, picture 3.
Place the cover over the assembly, picture 4, then turn the part over and secure it in place using 3 x F screws, picture 5.
That completes the assembly for this stage.
#2 Posted : 01 September 2026 08:37:26
Issue 64
Right Leg
Retrieve the assembly from the last issue and place one of the support bases onto the joint as shown in picture 2. Turn the assembly over and secure it in place using 2 x F screws, picture 3.
Now place the other support base and secure both in place using 4 x F screws as shown in pictures 4 and 5.
Now attach the assembly to the right thigh using 2 x F screws, pictures 6, 7 and 8.
Picture 9 shows the assembly stage complete for this issue.
#3 Posted : 02 September 2026 09:51:50
Issue 65
Right Leg
Slot the friction disc into the base and secure in place using 4 x Z screws, picture 2. Note: The magazine instructions show V screws, please use the Z screws as supplied.
Place the mobile bar of the right thigh on top of the friction disc and secure it in place using 3 x Q screws, picture 3.
Picture 4 shows the assembly stage complete for this issue.
#4 Posted : 04 September 2026 10:19:48
Issue 66
Right Leg
Take the previous assembly and attach the friction disc onto the thigh bar and secure it in place using 4 x J screws, picture 2.
Fit the rotating bar onto the assembly as shown in pictures 3 and 4. Turn the assembly over and secure it in place using 2 x F screws, picture 5. Turn the assembly back over and apply the friction pad by removing the protective film and stick it to the rounded upper part of the cover, picture 6.
Finally, attach the assembly to the mobile bar, securing it in place using 4 x Q screws as shown in picture 7.
#5 Posted : 04 September 2026 10:29:20
Issue 67
Right Leg
Retrieve the previous assembly and attach the two covers of the support around the base of the rotating bar, pictures 2 and 3. Place 2 x F screws on both sides as illustrated in pictures 4 and 5.
Retrieve the right thigh assembly from issue 64 and fit the rotating bar assembly by securing it using 2 x F screws as shown in pictures 6 and 7.
Now attach the front cover of the right thigh onto the assembly by placing 4 x F screws in the holes as shown in pictures 8 and 9.
#6 Posted : 05 September 2026 14:22:46
Issue 68
Right Leg
Retrieve the right thigh and knee assembly and attach one of the support bases as shown in picture 2. Turn the assembly over and secure it using 2 x F screws, picture 3. Note: the magazine does not show this part of the assembly.
Attach the other base support as you did with a previous assembly securing each side using 2 x F screws, pictures 4 and 5.
Attach the right calf cover onto the end of the knee joint, picture 6. Use 2 x F screws to hold the assembly in place, picture 7.
Picture 8 shows the assembly stage complete for this issue.
This page was generated in 0.211 seconds.
