Ferrari 330 P4 Official Build stages 105 - 110 Options
#1 Posted : 01 September 2026 15:21:12
STAGE 105:
Air intake and left wheel well.
Pic 1: Retrieve the upper and lower ready body panels.
Turn the upper panel upside down and fit the lower panel in place as shown.
Take care that the grilles indicated are fitted into the slots in the upper body.
Pic 2: Fix the parts using 6 x AM screws saved from the previous issue.
Pic 3: Fix with a further 4 x AM screws saved from the previous issue.
Pic 4: Soak the decal from the previous issue in warm water and then slide the decal in place, dabbing it down with a paper towel so it conforms to the body shape.
Pic 5: Fit the three number lights from the previous issue.
Make sure the white area on the lights face the numbers.
Pic 6: Save the body and unused parts safely for now.
#2 Posted : 04 September 2026 10:41:11
STAGE 106:
Air intake and right wheel well.
Pic 1: Fit the air intake parts 106A and 106B together as shown.
Pic 2: Fit the air intake parts 105A and 105B together as shown.
Pic 3: Fit 105A into the upper rear body where shown and fix with 1 x AP and 1 x AM screws.
Pic 4: Retrieve the rear lights ‘C’, ‘D’ ‘J’ and ‘K’.
Pic 5: Fit LED ‘K’ where shown.
Pic 6: Fit the 2 x LED’s ‘D’ where shown.
Pic 7: Fit LED ‘J’ where shown.
Pic 8: Fit the 2 x LED’s ‘C’ where shown.
Pic 9: Run the cables under 106A as shown and fix with 1 x AM and 1 x AP screws.
Pic 10: Store everything safely for now.
#3 Posted : 05 September 2026 11:52:39
STAGE 107:
Trunk partition and light housing.
Pic 1: Locate the partition parts 107A and 107B.
They will press-fit together.
Pic 2: Parts assembled.
Pic 3: Fit the assembly into the rear body as shown, noting where the light wires exit.
Fix with 2 x AM and 1 x AP screws.
Pic 4: Fit the wheel well 105C in place and fix with 4 x AM screws.
Pic 5: Tuck the LED wires behind the partition.
Store the body and unused parts safely.
#4 Posted : 06 September 2026 12:00:37
STAGE 108:
Pic 1: Locate the partition parts 108A and 108B.
Pic 3: Route the wires at the rear along the body as shown and fix with a strip of tape 108D.
Pic 4: Fit the assembly into the rear body as shown, noting where the light wires exit.
Pic 5: Route the wires along the inside of the body as shown and fix with strips of tape 108D.
Pic 6: Fit the wheel well 106C in place and fix with 4 x AM screws.
Pic 7: Tuck the LED wires behind the partition.
#5 Posted : 07 September 2026 10:13:26
STAGE 109:
Left hood components.
Pic 1: Fit the rear wing 109A in place on the rear body.
Pic 2: Fix from the inside with 2 x UM screws.
Pic 3: Fix the light housing 107C in place as shown with 2 x AM screws.
Pic 4: Fix the lower wing 109B in place with 2 x AM screws.
Pic 5: Press-fit the cover plate 109C in place.
Store safely for now.
#6 Posted : 08 September 2026 10:27:13
STAGE 110A:
Right hood components and completion.
Pic 1: If you have not already done so you can fit the wheels now using the parts saved.
Pic 2: Rear wheels fitted.
Pic 3: Fit the rear wing 110A to the rear body.
Pic 4: Fix from inside with 2 x UM screws.
Pic 5: Fix the light cover 108C using 2 x AM screws.
#7 Posted : 08 September 2026 10:30:40
STAGE 110B:
Pic 6: Fit the lower wing 110B with 2 x AM screws
Pic 7: Press-fit the cover 110C in place.
Pic 8: Use one of the cable ties to secure the wires together as shown and trim off the excess tie.
Pic 9: Repeat with the wires in the car.
Pic 10: Fit the upper body panel to the car and fix with 3 x ASM screws.
This is fiddly so be patient.
Pic 11: Connect the wires and plugs.
#8 Posted : 08 September 2026 10:33:11
STAGE 110C:
Pic 12: Well done.
You can now admire your completed model.
This page was generated in 0.299 seconds.
