Peugeot 205 Dakar Turbo Official Build STAGES 99 - 104 Options
#1 Posted : 27 August 2026 14:30:45
STAGE 99:
Chassis protector.
Pic 1: Place the car upside down and lay the chassis protector 99A also upside down in the position shown.
Fit the speaker in place where indicated and fix with the bracket 99B and 2 x AP screws.
Pic 2: Turn the chassis protector over, making sure the speaker wires are not trapped anywhere and fix with 6 x AM screws.
Pic 3: Fix with another 2 x CM screws.
Pic 4: Fit the battery cover from stage 51.
Pic 5: Fix the front mudguards with 4 x AP screws.
#2 Posted : 29 August 2026 17:29:52
STAGE 100:
Air filter and windscreen wipers.
Pic 1: Press-fit the filter parts 100A and 100B together.
Pic 2: Fix the assembly to the top rear of the car roof with 2 x TM screws and a further AP screw down the inside of the filter onto the injection pump.
Pic 3: Fit the sealing nut 100D to the filter cover 100C and then fit the assembly to the top of the air filter.
Pic 4: Press-fit the roof duct 100E in place as shown.
Pic 5: If you have not yet fitted the wheels they could be added now using 4 x AM screws saved from the wheel assembly stages in each wheel.
Repeat on the other side.
Pic 6: Fit the front wheels in the same way.
Pic 7: Fit the 4 x clips 100H to the two wipers.
These parts are a very loose fit so you may wish to use a little adhesive.
Press-fit the left and right wiper in place.
The wipers are marked ‘L’ and ‘R’.
Pic 8: Fit the locking pin 100I as shown.
You will find it far easier if you have the bonnet open.
Store safely for now.
#3 Posted : 31 August 2026 11:35:20
STAGE 101:
Rear Body.
Pic 1: Undo the screws indicated and remove the support strap on the body 101A.
Pic 2: Assemble the hinge parts 101B, 101C and 101D as shown.
Pic 3: Make two sets.
Pic 4: Fix the hinges to the roof of the car using 1 x AM screw in each.
Pic 5: Open the car bonnet and fit the spoiler 101E as shown.
The part is not a tight fit so you may wish to use small dots of adhesive on the locating pins.
Store the model and unused body part safely.
#4 Posted : 02 September 2026 10:24:40
STAGE 102:
Rear screen.
Pic 1: Fix the two spoiler brackets 102D to each side of the rear body with 1 x NP screw in each from behind.
Pic 2: Fix the supports 102C to each bracket using 1 x AEP screw in each.
NOTE – It might be advisable to fit these supports at a later stage when they are needed to avoid breaking them in the meantime.
The screws can be fitted to avoid losing them.
Pic 3: Retrieve the rear red/black LED cable numbered ‘14’.
Pic 4: Turn the rear body over and fit the cable as shown.
You can use a piece of tape to keep it in place.
Pic 5: Fit the rear screen of your choice in place by positioning the lower three tabs first and then applying gentle pressure to the centre of the screen to flex the upper three tabs into place.
Make sure the cable exits the screen at the top left where shown.
NOTE – The upper three tabs are quite thick and are difficult to get into place without cracking the screen at the top centre.
Another solution is to completely remove these tabs with a file and fix the upper edge of the screen with an adhesive such as Clearfix or PVA.
Do not use a cyano type glue as this will fog the screen.
#5 Posted : 03 September 2026 10:14:39
STAGE 103:
Rear spoiler.
Pic 1: Fix the brackets 103E and 103F to the spoiler ends 103C and 103D with 1 x ZP screw from behind in each.
Pic 2: Press-fit the two assemblies into the rear spoiler 103A.
They will only fit one way.
Pic 3: Retrieve the rear body and temporarily tape the spoiler upside down in place as shown.
Pass the LED wires through the holes as indicated.
The wires will locate in the notch highlighted.
Pic 4: Assemble the upper lights 103G and 103I, and 103H and 103I.
The units are marked ‘L’ and ‘R’.
Pic 5: Turn the spoiler over on the rear body.
Pic 6: Press the LED’s into the left and right light housings.
Pic 7: Turn the spoiler over again and fit the upper panel 103B as shown.
Use some low-tack tape to keep it in place.
Pic 8: Turn the spoiler over again and fix the parts with 7 x AP screws.
Pic 9: Turn the spoiler over and fix it to the rear upper roof using 2 x EP screws.
Pic 10: Connect support struts 102 C using the AEP screws.
#6 Posted : 04 September 2026 10:14:28
STAGE 104:
Rear bumper.
Pic 1: Fix the clear light 104C to the bumper 104A as shown with 1 x AM screw.
Pic 2: Fix the number plate 104B to the bumper with 2 x AP screws from behind.
Pic 3: Fit the latch brackets 104D as shown.
They are not a tight fit so you may wish to use a little adhesive on each.
Store the bumper and unused parts safely.
