World of Warcraft Lich King Pack 15 Options
#1 Posted : 31 August 2026 17:36:35
Issue 75
Sword
Place the blade into the handle assembly from issue 3 and secure it in place using 4 x PM screws as shown in picture 2.
Picture 3 shows the completed assembly for this issue.
#2 Posted : 01 September 2026 08:32:05
Issue 76
Picture 1 shows the contents of this issue. It also shows the parts in order of assembly.
Right Shoulder
Insert the upper joint of the right arm into the shoulder joint and secure in place using 2 x KP screws, picture 2.
#3 Posted : 02 September 2026 09:53:41
Issue 77
Upper Structure of the Right Arm
Attach the upper structure at the back of the arm and secure it in place using 4 x LP screws, picture 2.
#4 Posted : 03 September 2026 10:35:56
Issue 78
Place the upper arm joint onto the right arm and secure it in place using 2 x KP screws, picture 2.
Tip: Before we start with the next section, I would recommend using a pair of sturdy pliers to compress the spring. This will make it easier to fit into the part into the housing, picture 3.
Slide the spring onto the rod and insert the assembly into the base joint as shown in picture 4.
Insert the plate into the joint base, whilst simultaneously inserting the shaft pin, picture 5.
Insert the rod with the spring as shown in picture 6.
Attach the base cover to close the assembly using the nut and 2 x HM screws as shown in picture 7. Use the wrench that was provided in issue 7 to tighten the nut.
Attach the assembly to the right arm and secure it in place using 4 x SP screws, picture 8.
#5 Posted : 04 September 2026 10:00:48
Issue 79
Place the closing structure of the right arm and secure it in place using 4 x LP screws, pictures 2 and 3.
#6 Posted : 04 September 2026 10:10:34
Issue 80
Right Forearm
Place the right forearm cover onto the elbow joint and secure it in place using 2 x KP screws, picture 2.
