 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,816 Points: 17,600 Location: ipswich
STAGE 81A:
Centre console and control levers.
Pic 1: Fix the hinge 81H to the console lid 81G with 2 x NP screws. The short step on the hinge fits to the lid.
Pic 2: Fix the lid to the console 81F with 2 x NP screws.
Pic 3: Locate the gear lever parts 81J, 81L, 81M and 81N.
Pic 4: Fit the lever into the blue cover and then add the ball joint 81M from underneath.
Pic 5: Fit the assembly into the surround 81J.
Pic 6: Fix the retaining bracket 81K in place as shown with 2 x KP screws.
Pic 7: Press-fit the handbrake 81I in place.
STAGE 81B:
Pic 8: Fit the assembly to the console as shown and fix from underneath with 1 x CP screw.
Pic 9: Fit the control levers 81D and 2 x 81C to the upper steering cover 81A as shown.
Pic 10: Shows the correct position of the levers from above.
Pic 11: Fix the lower cover 81B in place with 2 x IP screws.
Pic 12: Press-fit the injection monitor 81E in place.
Pic 13: Fit the assembly to the dashboard as shown and fix from behind with 2 x IP screws.
Pic 14: Fit the dashboard to the interior assembly as shown and fix with 1 x IP screw at either end and 1 x IP screw underneath.
Pic 15: Fit the console assembly in place as shown and fix with 2 x CP screws from underneath.
Pic 16: Store everything including the unused screws safely for now.roymattblack attached the following image(s):
STAGE 82:
Left door 1.
Pic 1: Fix the door handle 82B to the door 82A with 2 x AP screws from behind.
Pic 2: Peel the backing from the mirror 82C and stick it onto the mirror body 82C.
Pic 3: Fix the mirror to the door with 1 x GP screw from behind.
Store safely for now.
STAGE 83:
Left door 2.
Pic 1: Fix the control panel 83D to the inner door 83A with 1 x AP screw from behind.
Pic 2: Press-fit the lock parts 83E and 83F to the door pull 83B as shown.
Pic 3: Press-fit the upper trim 83C in place.
Pic 4: Fix the assembly to the door with 2 x AP screws from behind.
Pic 5: Press-fit the speaker 83G into the door as shown.
Pic 6: Fix the door catch 83H to the inside of the door panel with 1 x AP screw.
STAGE 84:
Left door 3.
Pic 1: Fit the window mechanism parts 84C and 84E together as shown and fix with 1 x DP screw.
Pic 2: Fit the lever 84D in place as shown and fix with 1 x DP screw.
Pic 3: Fit the regulator arm 84F as shown and fix with 2 x DP screws.
Pic 4: Fit the window 84A to the assembly and fix with 2 x JP screws.
Pic 5: Retrieve the door panel83A and fit the window and mechanism as shown. Fix with 2 x DP screws and 1 x AP screw.
Pic 6: Retrieve outer door 82A and fix the hinges 84B as shown using 2 x GM screws.
Pic 7: Fit the inner and outer door panels together and fix with 5 x QM screws. Check the window operates correctly by turning the wheel at the bottom of the door.
Store safely for now.roymattblack attached the following image(s):
STAGE 85:
Main body.
Pic 1: Remove the support straps under the body.
Pic 2: Fit the left reflector 85B (L) into the left rear of the body.
Pic 3: Secure in place with the backing plate 85C (L) and 2 x JM screws.
Pic 4: Repeat on the other side with the right hand parts.
Pic 5: Assemble the fuel filler parts 85H, 85I and 85J.
Pic 6: Fit the assembly in place in the body and fix with 1 x GM screw.
Pic 7: Fit the cover 85G by fitting the upper edge in place first, then the lower.
Pic 8: Fit the aerial base 85F and fix from underneath with 1 x DP screw.
STAGE 86:
Right door 1.
Pic 1: Fix the door handle 86B to the door 86A with 2 x AP screws from behind.
Pic 2: Peel the backing from the mirror 86C and stick it onto the mirror body 86C.
