Caronade. Options
mark 2
#1 Posted : 04 September 2026 19:08:33
Hi everyone.
I have the Caronade from issue 3 but can anyone tell me what issue.we get the second Caronade in as I seem to only have the one from issue 3.
Any help would be greatly appreciated.
Thanks and best regards to all.
#2 Posted : 05 September 2026 10:19:08
Hi Mark
These kits were built by the forum support team several years ago, who are not longer around. My only suggestion to you is to look at the official build logs which should give you an indication of what issue the second one came in.
GilShapley
#3 Posted : 08 September 2026 14:16:02
It’s some time since I built my Victory, but I still have the Builds Guides, Both the original Mags plus guides in PDF format on my PC (Easier to store)
As you know Page 95 Stage 3 tells you how to construct the Carronade. It also refers you to Stage 1 Pack 1 for more instructions.
The contents list for stage one has the following:-
Stage 1: Assembling the bow frames and 12-pounder gun
I can’t be sure but this implies the cannon was provided with issue 1
Hopes this helps
Gil
Current Build:-
This page was generated in 0.136 seconds.
