1989 Batmobile Official build STAGES 51 - 56 Options
#1 Posted : 05 September 2026 11:49:07
STAGE 51:
Interior rear wall.
Pic 1: Press-fit 50-1 from the previous issue into the two slots on the rear wall 51-1.
Pic 2: Fix the panel 51-2 to the rear wall using 2 x D screws.
Pic 3: On the other side, fit the lighting panel 51-3.
Pic 4: Fix the LED box 50A from the previous stage using 2 x D screws.
The wire will exit from the cut-out on the base of the box.
Pic 5: Fix the assembly to the interior as shown with 2 x D screws.
Store safely for now.
#2 Posted : 06 September 2026 12:08:42
STAGE 52:
Interior side panels.
Pic 1: Retrieve the interior assembly and place it upside down.
Fix the 6 x brackets 52-3 as shown using 1 x D screw in each.
Pic 2: Fit the side panel 52-1 as shown and fix using 4 x D screws.
Pic 3: Fit the side panel 52-2 as shown and fix using 4 x D screws.
#3 Posted : 07 September 2026 10:08:00
STAGE 53:
Front left suspension.
Pic 1: Fit the shock absorbers 53-2 to the ‘Y’ arm 53-3 as shown and fix with 1 x F screw.
Pic 2: Fix the 2 x brackets 53-4 to the ends of the ‘Y’ arm in the positions shown using 1 x F screw in each.
Pic 3: Fix the assembly to the upright 53-1 as shown using 1 x G screw from underneath.
Pic 4: Store safely for now.
This page was generated in 0.128 seconds.
