Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,416 Points: 22,558 Location: Northamptonshire, England
Issue 104
Hood Inner Reinforcement. Place the hood latch 104 B on the outside of the hood in a reinforcement 104 A. Note there is only one way this will mount as the latch has one side longer than the other. Turn the assembly over and secure it in place using a PS31 screw as shown in pictures 2 and 3.
Issue 105
Hood Place the inner reinforcement on the underside of the hood and make sure that the four protrusions on the hood fit snugly into the holes in the reinforcement. Fix the reinforcement to the hood with four DS35 screws as shown in picture 2.
Issue 106
Left Front Fender Separate this sticker with the emblem (106C) from its backing. Attach the sticker to the emblem base (106B), picture 2. Now attach the emblem to the rear side of the left front fender as shown in picture 3.
Turn the assembly over and fix the base with a PS17 screw from the inside, picture 4.
Pictures 5 shows the final assembly for this issue.
Issue 107
Chassis Front Panel Place the right hood support (107C) identified with an R on its base, on the outer face of the chassis front panel (107A). Push the thin pin into the front panel, picture 2, then turn the front panel over and secure the support using a PS08 screw as shown in picture 3.
Repeat the previous step and place the left hood support 107B, identified with an L on its base, picture 4.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 108
Right Front Fender As you did in issue 105, attach the emblem base (108B) to the rear of the right front Fender (108A), picture 2.
Retrieve the chassis front panel. Put it alongside the right front Fender so you can see where the two parts are attached, picture 3. Fix the panel to the Fender using 2DS10 screws through the front of the assembly as shown in picture 4.
Now retrieve the left front Fender and position it in the same way as the right front Fender. Secure it in place using two DS10 screws, picture 5.
