BTTF Delorean Official build STAGES 82 - 86 Options
#1 Posted : 09 September 2026 10:30:00
STAGE 82:
Engine surround.
Pic 1: Fix the 3 x connectors 82B in place on the surround using 3 x AP screws underneath.
They will only fit one way.
Pic 2: Fix the 3 x batteries 82G in place on the surround using 3 x BP screws underneath.
Pic 3: Connect the red/yellow wires 3 x 82C to the batteries as shown with 3 x MP screws.
Pic 4: Connect the red/blue wires 3 x 82D to the batteries as shown with 3 x MP screws.
Pic 5: Connect the green/yellow wires 3 x 82E to the batteries as shown with 3 x MP screws.
Pic 6: Fold the wires back on themselves and tuck them under the notch in the engine surround.
Pic 7: Secure the wires with the tab 82F, fixing it with 1 x AM screw.
Trim off the excess wire if you wish.
Pic 8: Push-fit the cable 82A in place as shown.
Store safely for now.
#2 Posted : 10 September 2026 10:11:04
STAGE 83A:
Engine surround.
Pic 1: Locate the cylinders and mesh parts 2 x 83D and 2 x 83E.
Pic 2: OPTIONAL DETAIL – You can colour the central surface of the cylinders black with paint or marker pen to highlight the holes in the mesh when assembled.
Pic 3: Wrap the mesh around the cylinders and fix with 2 x MP screws in each.
Pic 4: Fix the cylinders to the base 83F with 2 x AP screws.
Pic 5: Fix the assembly to the engine surround with the cylinder screws facing inward using 1 x AP screw from underneath.
Pic 6: Fix the storage units 83G in place with 1 x AP screw from underneath.
#3 Posted : 10 September 2026 10:15:59
STAGE 83B:
Pic 7: Fix the 4 x spring wires 83H to the top of the cylinders with 4 x MP screws.
Pic 8: Feed the wires through the large hole in the engine surround where indicated.
Pic 9: Feed the coloured wires 83K through the same hole from above and then secure all wires using the tab 83I and 1 x AM screw.
Trim off any excess wire if you wish.
Pic 10: Fold the coloured wires 83K back over the engine surround and fix with the tab 83J and 2 x AM screws.
Pic 11: Press-fit the pipe 83A in place where shown.
Pic 12: Fit the cylinders 83B and 83C together.
Pic 13: Fix to the engine surround with 2 x AP screws from underneath.
Pic 14: Form a loop in the coloured wires 83K and wrap it around the blue and green cylinders as shown.
#4 Posted : 11 September 2026 10:19:33
STAGE 84:
Engine bay.
Pic 1: Fix the 2 x brackets 84F to the firewall 84E with 4 x AP screws from behind.
Pic 2: Fix the 2 x tank parts 84H and 84I together with 2 x AP screws.
Pic 3: Fit the tank cap 84G.
Pic 4: Fix the tank to the brackets with 4 x AP screws.
Pic 5: Fix the torsion bar 84C to the firewall as shown with 1 x AP screw.
Pic 6: Press-fit the support 84B in place as shown.
Pic 7: Retrieve the engine surround and place it upside down.
Fix the firewall part 84A with 2 x DM screws.
Pic 8: Fix the firewall part 84D with 2 x DM screws.
Pic 9: Fix the firewall part 84E with 2 x DM screws.
Pic 10: Fix 2 x AP screws where indicated.
Pic 11: Store safely for now.
#5 Posted : 11 September 2026 23:22:04
STAGE 85:
Engine bay.
Pic 1: Retrieve the assembly from the previous stage and fit the rear firewall 85A as shown.
Fix with 4 x BP screws.
Pic 2: Fix with 2 x DM screws, one on each side.
Pic 3: Fix the rear bulkhead 85D as shown using 3 x CM screws.
Pic 4: Connect the blue plug where indicated.
Pic 5: Assemble the engine bay light parts 85B and 85C as shown.
Pic 6: Fit the light in place on 85A where indicated and fix with 2 x AP screws from the other side.
Pic 7: Retrieve the main body and place it upside down.
Make sure all the roof wires are facing forward.
Pic 8: Fit the engine bay inside the rear of the body and fix with 4 x DM screws where shown.
Make sure the bundle of coloured wires goes to the outside of the body as seen in pic 10.
Pic 9: Fix the other side with another 4 x DM screws.
Pic 10: Store safely for now.
This page was generated in 1.166 seconds.
