 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,700 Points: 17,252 Location: ipswich
STAGE 51:
Interior rear wall.
Pic 1: Press-fit 50-1 from the previous issue into the two slots on the rear wall 51-1.
Pic 2: Fix the panel 51-2 to the rear wall using 2 x D screws.
Pic 3: On the other side, fit the lighting panel 51-3.
Pic 4: Fix the LED box 50A from the previous stage using 2 x D screws. The wire will exit from the cut-out on the base of the box.
Pic 5: Fix the assembly to the interior as shown with 2 x D screws.
Store safely for now.
STAGE 52: Interior side panels. Pic 1: Retrieve the interior assembly and place it upside down. Fix the 6 x brackets 52-3 as shown using 1 x D screw in each. Pic 2: Fit the side panel 52-1 as shown and fix using 4 x D screws. Pic 3: Fit the side panel 52-2 as shown and fix using 4 x D screws. Store safely for now. roymattblack attached the following image(s):
STAGE 53:
Front left suspension.
Pic 1: Fit the shock absorbers 53-2 to the ‘Y’ arm 53-3 as shown and fix with 1 x F screw.
Pic 2: Fix the 2 x brackets 53-4 to the ends of the ‘Y’ arm in the positions shown using 1 x F screw in each.
Pic 3: Fix the assembly to the upright 53-1 as shown using 1 x G screw from underneath.
Pic 4: Store safely for now.
STAGE 54:
Front left brake.
Pic 1: Locate the disc parts 54-3 and 54-4. They will fit together.
Pic 2: Peel the backing from 54-4 and stick it to the face of 54-3.
Pic 3: Fit the disc centre 54-5 from underneath, add the other disc half 54-2 and fix the parts with 2 x ‘I’ screws.
Pic 4: Retrieve the upright assembly from the previous stage and fix the caliper 54-1 in place as shown with 1 x ‘A’ screw.
Pic 5: Press-fit the backing plate 54-6 in place.
Pic 6: Store safely for now.
STAGE 55:
Left fuel tank.
Pic 1: Fit the tank parts 55-1 and 55-2 together as shown.
Pic 2: Fix from underneath with 4 x D screws.
Pic 3: Press-fit the tank fittings 55-4 in place. They will only fit one way.
Pic 4: Fix the tank base 55-3 in place with 2 x D screws. It will only fit one way.
Store safely for now.roymattblack attached the following image(s):
STAGE 56:
Fuel tank hoses.
Pic 1: Feed the 4 x washers 56-4 over the hose 56-1, keeping them equally spaced along the hose.
Pic 2: Feed the 2 x smaller tubes 56-2 through the outer holes in each washer.
Pic 3: Fit the fuel filler neck 56-3 as shown, paying attention to where the hose and tubes connect.
