Peugeot 205 Dakar Turbo Official Build STAGES 105 - 110 Options
#1 Posted : 15 September 2026 19:09:58
STAGE 105:
Rear lights and grille.
Pic 1: Retrieve the rear body and fit the tail lights 105B and 105D as shown.
Fix from behind with 2 x AP screws in each.
Pic 2: Press-fit the light covers 105C and 105E.
Pic 3: Turn the assembly over and fit the grill 105A as shown and fix with 3 x AM screws on the inside.
Pic 4: Fix the bumper from stage 104 as shown using 5 x AM screws.
Pic 5: Store safely for now.
#2 Posted : 17 September 2026 10:25:08
STAGE 106:
Rear body inner shell.
Pic 1: If you have not already done so, disconnect the 4 x wires/plugs at the rear of the car.
Pic 2: Retrieve the rear body and place it so you can work on the inside.
Plug the shorter wire LED on wire 15 into the lower hole on the right light cluster.
Pic 3: Plug in the LED’s on wire 13 as shown.
Pic 4: On the other side, add LED 15 in the lower hole.
Pic 5: Connect the 2 x LED’s on wire 12 as shown.
Pic 6: Carefully run all the wires around the inside of the body as shown and tape in place with pieces of tape 71D.
NOTE – It is important that you keep the wires flat and side-by-side.
Pic 7: Fit the inner shell 106A in place, checking that the wires all pass through the cut-outs in the lower corners and top right.
Fix with 6 x AM screws where shown.
Pic 8: Fix with another 5 x AM screws in the roof section.
At this stage you can reconnect the wires/plugs, add batteries and test the light functions.
Disconnect the wires/plugs afterwards.
Pic 9: Store safely for now.
#3 Posted : 18 September 2026 10:00:20
STAGE 107:
Rear left window.
Pic 1: Choose which window glass you wish to use – 107A or 107B.
Press-fit the glass into the frame 107C.
Pic 2: Fix the air intake part 107E to the frame using 2 x AP screws.
Pic 3: Fix the outer panel 107D to the assembly with 2 x AP screws.
#4 Posted : 19 September 2026 11:35:13
STAGE 108:
Rear right window.
Pic 1: Choose which window glass you wish to use – 108A or 108B.
Press-fit the glass into the frame 108C.
Pic 2: Fix the air intake part 108E to the frame using 2 x AP screws.
Pic 3: Fix the outer panel 108D to the assembly with 2 x AP screws.
#5 Posted : 20 September 2026 11:38:49
STAGE 109:
Rear air intakes.
Pic 1: Fix the 2 x air intake assemblies from the previous stages to the frame 109C with 2 x AAP screws.
Pic 2: Fix the grille 109D in place with 4 x AAP screws.
Pic 3: Fit the assembly inside the rear body as shown.
Check the front corner clips highlighted in green are attached and then fix with 6 x AM screws.
Pic 4: Fix the 2 x inner arches 109A and 109B with 2 x AM screws in each.
#6 Posted : 21 September 2026 10:17:19
STAGE 110A:
Traction boards and completion.
Pic 1: Fix the 4 x brackets 110D to the rear body using 1 x QM screw in each.
Pic 2: Cut 4 x pieces of 3mm tube from 110J.
Pic 3: Fit the retaining pins 110E to the brackets and fit a 3mm piece of tube 110J over the other end to secure them.
Pic 4: Fit the belt 110G through the buckle 110F as shown.
Fix a sticky tab 110K where indicated.
Pic 5: Peel the backing from the tab and wrap the belt around, sticking it down to the tab.
Pic 6: View from the other side.
Pic 7: Make 2 x sets.
Pic 8: Feed the belt down through the brackets on the rear of the body.
#7 Posted : 21 September 2026 10:20:40
STAGE 110B:
Pic 9: Pass the lower end of the belt up and through the buckle as shown.
Pic 10: Repeat on the other side.
Pic 11: Fit the traction boards 110C in place and pull the belts tight.
Fix the loose end of the belt using 1 x tab 110K on each.
Pic 12: Fit the rear body in place on the car, locating the hinges where shown.
Pic 13: From the inside, fix the hinges using 1 x AM screw in each.
Pic 14: Carefully reconnect the wires and plugs.
Pic 15: Fit the locking pins from stage 104 where shown.
They are extremely loose so you may wish to use a dot of adhesive on each.
Pic 16: Position the two spare shock absorbers from stages 63 and 64 where shown.
Pic 17: Fit the light covers 110A and the pins 110H as shown.
Repeat on the other side of the car.
#8 Posted : 21 September 2026 10:24:04
CONGRATULATIONS!
You have now completed your Peugeot 205 turbo 16.
Display it with pride!
This page was generated in 0.531 seconds.
