 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,856 Points: 17,720 Location: ipswich
STAGE 92:
Rear lights.
Pic 1: Connect cable 92A (10) to cable 10 exiting the rear right light aperture on the body.
Pic 2: Fix the wire to the body as shown with tab 92C and 1 x AP screw.
Pic 3: Retrieve the rear bumper assembly from stage 1 and carefully undo the fixing clips indicated.
Pic 4: Remove the rear bumper.
Pic 5: Fit the LED panels 92B as shown and fix the wires with 2 x tabs 92C and 2 x KM screws.
Pic 6: Cover the rear of the LED panels using 2 x strips 92D.
Pic 7: Connect the wires and plugs as shown.
Pic 8: Feed the plugs and wires back into the light aperture and then fix the rear panel in place with 3 x DM screws.
Pic 9: Press-fit the rear bumper panel back in place.
Store safely for now.roymattblack attached the following image(s):
STAGE 93:
Front lights.
Pic 1: Fit the grille 93B to the front panel 93A.
Pic 2: Fix from behind with 2 x BP screws.
Pic 3: Fit the 4 x front lights 93C. Each clear lens has a small raised dot – highlighted in red. This must be at the top.
Pic 4: Fix from behind with 2 x BP screws in each light.
Pic 5: Fit the LED wire 93D as shown with the plug on the right.
Pic 6: Fit the lower LED cable 93E as shown with the plug on the right and the LED’s passing through the holes in the lower panel.
Pic 7: Store safely for now.
STAGE 94:
Valance and grille.
Pic 1: Fix the valance 94A to the bottom of the previous stage with 2 x DM screws.
Pic 2: Fix the grille 94B in place with 4 x DM screws along the upper edge, and 4 x IP screws at the bottom.
Pic 3: Connect the wires and plugs at the front of the car as shown.
Pic 4: Taking care not to trap any wires, fix the front in place on the body as shown using 3 x DM screws.
STAGE 95:
Bumper, lower lights and brackets.
Pic 1: Fix the orange light cover 95C to the bumper 95B as shown using 2 x AP screws. Repeat at the other end of the bumper.
Pic 2: Fix the 6 x 95A brackets to the bumper using 1 x LP screw in each from behind.
Pic 3: Press-fit the LED’s into place as shown.
Pic 4: Carefully feed the wiring back into the body so you can fit the bumper, then fix with 4 x DM screws. Make sure the wrap-around ends are seated properly in their recesses.
STAGE 96:
Lower side valance.
Pic 1: Holding the driver’s door open carefully, fit the valance 96A in place making sure the front and rear ends are tucked inside the body. Fix in the door step with 2 x NM screws.
Pic 2: Peel the backing from the tread plate 96B and stick it in place where shown. Make sure the ‘DMC’ is the right way up.
