BTTF Delorean Official build STAGES 97 - 101 Options
#1 Posted : 21 September 2026 10:35:31
STAGE 97:
Lower side valance.
Pic 1: Holding the passenger door open carefully, fit the valance 97A in place making sure the front and rear ends are tucked inside the body.
Fix in the door step with 2 x NM screws.
Pic 2: Peel the backing from the tread plate 97B and stick it in place where shown.
Make sure the ‘DMC’ is the right way up.
Store safely for now.
#2 Posted : 22 September 2026 13:13:13
STAGE 98:
Power coil lighting.
Pic 1: Remove the tape from the LED.
Pic 2: Use a piece of tape 98G to wrap around the LED and the 2 x clear filaments 98F.
Make sure the ends of the filaments are in contact with the LED.
Pic 3: Locate the power box parts 98A (L) and 98B.
Pic 4: Fix the filaments and LED into the box 98B with the bracket 98A and 2 x IP screws.
Pic 5: Fix the box to the front of the car as shown using 1 x KM screw.
Pic 6: Press the cover 98C in place and fit the filaments into the brackets as shown.
Pic 7: Connect the other ends of the filaments to the LED on the other side.
Pic 8: Fix the power box in place as before and fit the filaments into the brackets on that side.
Store the car safely for now.
#3 Posted : 23 September 2026 10:00:04
STAGE 99:
Power coil frame and grilles.
Pic 1: Press-fit the frame 99A into the clips as shown making sure the ends highlighted go into the holes in the power box on both sides.
Pic 2: Fix the grille 99B on the driver’s side using 2 x AP screws and 2 x IP screws.
The grill should curve downwards at the front.
Repeat with grille C on the other side.
Pic 3: Fit the central grille 99D by fixing the centre first with 2 x IP screws, then working outwards with AP screws.
Hold grilles 99B and 99C in place over the ends of 99D as you fit the screws.
Store the car safely.
#4 Posted : 23 September 2026 16:31:21
STAGE 100:
Cables, wires front left.
Pic 1: Attach the fitting 100A to the end of the cable 100C.
Pic 2: Fix the fitting to the left power box with 1 x IP screw.
Attach the cable to the side of the car with the pins/locating holes.
Pic 3: Connect the wires 100D to the power box as shown.
Pic 4: Using pieces of the wire 100B, attach the coloured wires to the cable at intervals by twisting the wire around them. Trim off any excess.
#5 Posted : 24 September 2026 13:21:27
STAGE 101:
Cables and wires left.
Pic 1: Locate the mesh 101C.
Pic 2: Wrap the mesh around the tube 101B and fix with 3 x MP screws when you have the holes in the mesh and the tube aligned.
Pic 3: Fit the brackets 101A to each end of the tube as shown.
Pic 4: With the car upside down, fix the tube to the left side using 2 x KM screws.
Pic 5: Press-fit the cable 101E into place where shown.
Make sure the lower end goes into the silver tube.
Pic 6: Fix the upper cable 101F in place as shown, highlighted in yellow.
Pic 7: Fit the other end of the cable to the bulkhead as shown in yellow.
Pic 8: Fit the wire connector parts 101I and 101H together.
Pic 9: Unravel one end of the wires101G.
Pic 10: Fix the connector to the bulkhead with 2 x MM screws but do not tighten them yet.
Fit the wires into the connector as shown and then tighten the screws.
Pic 11: Feed the wires down the side of the car and fix them at intervals using pieces of wire 101D twisted around the black cable.
Trim off the excess wire and fold it flat.
Cut the end of the bunch of wires so it is just long enough to locate in the lower silver tube.
Pic 12: Fit the black cable and bunch of wires at the front of the car in the same way.
This page was generated in 2.389 seconds.
