1:6 Shelby Mustang Issues 109 - 113 (Pack 24) Options
#1 Posted : 25 September 2026 10:26:35
Issue 109
Bodywork
Carefully store the bodywork until needed next time.
#2 Posted : 25 September 2026 10:32:09
Issue 110
Side Air Intakes
Attach the right lower air intake, marked with an “R” inside, and insert the two pins. From the inside secure it in place using a PS08 screw, pictures 2 and 3.
Do the same with the right upper air intake, securing it in place using a PS05 screw, picture 4.
Now repeat the process with the left-hand side.
Pictures 5 shows the final assembly for this issue.
#3 Posted : 26 September 2026 17:32:36
Issue 111
Hood Hinges
Place the left hinge on the left hinge support and secure them using a PS02 screw, pictures 2 and 3. Do the same with the right hinge parts. Secure the right hinge assembly to the hood as shown in picture 4 using a DS19 screw.
Now, position the right hinge support, so that the cutout at the base fits into the frame inside the hood and the rectangular protrusion of the support is inserted into its slot. Secure it in place using a DS19 screw, picture 5. Install one of the hinge springs as illustrated in picture 6.
Repeat the process with the left hinge parts, picture 7. Picture 8 shows the two hinges in place on the inside of the hood.
Retrieve the fender assembly and place the right and left hinge covers as shown in picture 9, using a DS19 screw to each cover.
#4 Posted : 28 September 2026 10:30:07
Issue 112
Front Bumper
Retrieve the front bodywork and place the front bumper over the licence plate by inserting the two pins on the bumper into the two holes in the bodywork, picture 2.
Retrieve the hood and place the two hood pin plates on their mounting points, picture 3.
Place the right and left horns into the fender assembly and secure both using a DS02 screw, picture 4.
Place the hood pins on both the left and right hood supports and secure them in place using a PS12 screw, pictures 5 and 6. Note the pins have a “D” shaped bottom, so they will only fit one way.
Pass the free end of the two hood pin wires through the holes in the hood support and twist the end of the cables to hold them in place, pictures 7 and 8.
#5 Posted : 30 September 2026 10:46:01
Issue 113
Central Headlights
Place the headlight lens in both the right and left headlight reflectors, picture 2, then place both the assemblies into the headlight housing, picture 3.
Retrieve the front bodywork and on the inside attach the front grill using 2 x DS34 screws, picture 4.
Place the front grill sticker onto the grill badge as shown in picture 5, then attach it to the grill, pushing it through the holes on the right-hand side, picture 6.
Retrieve the fender and attach the headlight bracket, noting its orientation. Secure it in place using 2 x DS34 screws, picture 7.
This page was generated in 0.103 seconds.
