 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,751 Points: 17,405 Location: ipswich
STAGE 57:
Front chassis.
Pic 1: Fit the suspension assembly from stage 54 to the chassis 57-1 as shown.
Pic 2: Fix the parts with 2 x D screws.
Store safely for now.
STAGE 58:
Front suspension 2.
Pic 1: Fix 2 x brackets 58-3 to the front chassis as shown with 1 x D screw in each. Note the raised side of the bracket faces inwards.
Pic 2: Repeat on the other side.
Pic 3: Fix a suspension arm 58-1 to the brackets using 1 x F screw on each side, from the outside. Note the arm curves downwards.
Pic 4: Repeat on the other side.
Pic 5: Fix the top plates 58-2 on each side of the frame as shown using 2 x D screws in each. The top plates will only fit one way.
Pic 6: Lift the hub and fix it to the suspension arm as shown with 1 x G screw.
Pic 7: Fix the shock absorbers in place with 2 x R screws in each.
Store safely for now.roymattblack attached the following image(s):
