Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,295 Points: 22,192 Location: Northamptonshire, England
Issue 45
Take the sensor mounting bracket and place it onto the left front brake caliper mounting, securing it in place using 2 x KM screws as shown in pictures 1, 2, and 3.
Fit the two halves of the sensor sleeves together and secure them at the top using a ACP screw, pictures 4 and 5. Fit the cap at the other end, then insert the sensor rod, pictures 6 and 7.
Attach the assembly to the left folk leg and fix it in place using a KM screw, picture 8.
Note: the magazine refers to attaching the sensor mounting bracket (45F) in this next stage, this should read connector plate (45E)
Before attaching the connector plate, I would recommend attaching the ACP screw to the end of the sensor rod first, picture 9. Complete the assembly by securing the connector plate as shown in picture 10.
