Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,312 Points: 22,243 Location: Northamptonshire, England
Issue 114
Headlights and Wiring Retrieve the chassis assembly and place the instrument light wires in position at the back of the dashboard as shown in picture 2.
Retrieve the front bodywork and attach the lower front grille and fix it in place using 2 x DS02 screws picture 3.
Place the left and right headlight lens on the left headlight reflectors by push fitting them both in place, picture 4.
Place the headlights on the inside of the front of the body and secure both in place using a DSO2 screw as shown in picture 5.
Attach the cable 11 to the left headlight and cable 12 to the right headlight. Now attach cable 13 to the left turn signal reflector, whilst connecting the cable 14 to the right, picture 6.
Place the front bodywork onto the front fender assembly, carefully feeding the cables to the light either side through the gap as shown in picture 7.
Secure the two body assemblies together using 4 x DS02 screws, picture 8.
Turn the assembly over and run the cables along the underside of the body securing them in place using the wire retainers as shown in picture 9.
Now fit the centre headlights and secure them both in place using 4 x PS05 screw, pictures 10 and 11. Fit the LEDs inside the reflectors, picture 12.
Pictures 13 shows the final assembly for this issue.
Issue 115
Trunk Lid Separate the Shelby logo sticker and place it onto the Shelby badge, picture 2.
Place the Logo onto the rear of the trunk lid as shown in picture 3.
Issue 116
Trunk Lid inner Reinforcement Place the trunk latch into the trunk inner reinforcement. Note that the base of the latch has a pin that fits into a hole in the reinforcement that determines the correct mounting position, Secure the part using 2 x PS01 screws, picture 2.
Retrieve the trunk lid and place the inner panel on the inside and secure it using 2 x DS02 screws, picture 3.
Issue 117
Trunk Lid Seal and Hinges Take the trunk leg seal and remove the central section with a cutting tool, picture 2. Place the seal on the trunk lid in a reinforcement section as shown in picture 3.
Attach both the hinges, which are marked with an L and an R on the underside of the trunk lid. Secure these in place using 2 x DS02 screws to each hinge, picture 4.
Retrieve the bodywork and insert the trunk assembly so the arms of the hinge fit into the slots in the body, picture 5.
Finally, attach the hinge retainer plates over the ends of the hinges and secure in place using a DS02 screw. Note that the plates have a hole that fits into the pin on the bodywork, picture 6.
One final note. If the trunk lid is difficult to open, I would recommend pushing it open from the inside with the bodywork upside down. Before doing this, place the assembly on a soft towel so not to scratch the paintwork. You may need to use a little force but once freed it will open more easily.
Picture 7 shows the assembly complete for this issue.
Issue 118
Taillight Panel Place the fuel cap hinge into the square recess in the fuel cap base. Fix the hinge with the PS15 screw, picture 2. Now place the free hinge blade on the back of the fuel filler cap and secure it with another PS15 screw, picture 3.
Retrieve the body and open the trunk lid. Attach the fuel closure support and secure in place using a PS11 screw, pictures 4 and 5.
Now place the taillight panel on the rear of the body and secure in place using 4 x DS12 screws, pictures 6 and 7.
Install the fuel cap assembly into the centre hole of the panel, pictures 8 and 9.
Picture 10 shows the assembly complete for this issue.
