 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,766 Points: 17,450 Location: ipswich
STAGE 33:
Left rear frame.
Pic 1: Locate the 2 x cable extenders 33B. Fix the self-adhesive labels to each so that one cable is labelled at each end ‘S’ and the other cable ‘T’.
Pic 2: Place the frame 33A so that the screw posts highlighted are facing up.
Pic 3: Place the cables between the posts as shown with the socket ends to the left as shown in pic 4: Fit the clamps 4 x 33E in place and fix with 2 x G screws in each.
Pic 4: The socket ends of the cables must be to the left as shown.
Store safely for now.
STAGE 34A:
Left air intake and filter.
Pic 1: Fix the 2 x brackets 34A and 34B to the frame from the previous stage using 2 x G screws. They will only fit one way.
Pic 2: Fix parts 34C and 34D together as shown with 2 x B screws.
Pic 3: Fit the mesh 34E in place where indicated. It will only fit one way.
Pic 4: Fix the cover 34F in place with 2 x B screws.
Pic 5: Fit the filter housing parts 34G and 34H together and fix down the side with 1 x B screw.
STAGE 34B:
Pic 6: Fit the two assemblies together. They will only fit one way. Fix with 1 x B screw.
Pic 7: Fix the other side with another B screw.
Pic 8: Locate the left pipe 34I. It is marked on one end ‘L’. Fix it to the assembly as shown with 2 x B screws. The small horizontal mark should face down.
Pic 9: Locate the right pipe 34J. It is marked on one end ‘R’. Fix it to the assembly as shown with 2 x B screws. The small horizontal mark should face up.
Pic 10: Fix the assembly to the brackets installed on the frame at step 1 using 1 x B screw in each bracket. The assembly will only fit one way.
Pic 11: A different view.
Pic 12: A different view.
Store safely for now.roymattblack attached the following image(s):
