Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,312 Points: 22,243 Location: Northamptonshire, England
Issue 81
Picture 1 shows the contents of this issue. It also shows the parts in order of assembly.
Right Wrist Joint Insert the shaft into the joint base and insert the shaft pin, picture 2. Place the spring over the rod then place them into the joint base as shown in picture 3. Place the joint base cover on top and secure it in place using pin nut and 2 x HM screws, picture 4.
Place the assembly into the wrist joint, picture 5, then secure it in place by attaching the support and fixing it in place using 3 x UP screws, picture 6.
Attach the wrist joint to the right forearm, picture 7 and secure it in place using 4 x KP screws, picture 8.
Issue 82
Right Thumb and Shoulder Pad Support Insert the shoulder pad support A inside the support B and place the smaller of the pins to hold them in place, picture 2. Next, place the shoulder pad joint on the told and hold it in place using the larger pin as shown in picture 3.
As you dis with the previous hand, identify all the small figure and thumb segments. Take the thumb structure and place the first top three segment by push fitting the parts in place, picture 4. Do the same with the bottom segments, picture 5.
Picture 6 shows the completed assembly for this issue.
